Metallic "Clunk" when rolling from a stop (99 S70 T5M) Topic is solved
Levinicus
Year and Model: 1999 S70 T5M SR
Post by Levinicus »
1999 S70 T5 manual. Just started today. When I set off in 1st gear after turning the car on, there is a metallic sounding "clunk" from the front of the car. It happens around 2000 RPM, and only the first time setting off after the car is turned on. If I come to a full stop and accelerate again, it doesn't happen. There is stuff going on with the clutch/flywheel as of a few weeks ago (I think the dual mass flywheel has play in the bearing), but the clunk noise just started today. Any ideas what it could be?
99 S70 T5M - Turbobrick
00 Jeep XJ Sport - Mountainbrick
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Does it happen right at 12 MPH? Because that would be the ABS selt-test. It only does it once after the car is started.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Levinicus
Post by Levinicus »
ecbsykes wrote: 22 Apr 2017, 18:50 Does it happen right at 12 MPH? Because that would be the ABS selt-test. It only does it once after the car is started.
Wait, for real? I just fixed the abs/stc module. Yes, it happens right around 12 I think... I'll have to test it.
FlyingVolvo
Haha, yup! If your ABS was broken that's probably why the sound seems new to you. It's almost exactly like you described.. sort of a metallic crunching noise that lasts half a second. Sometimes you can feel a little vibration as it does it. Perfectly normal! Sounds like to me that you fixed your ABS. :mrgreen:
2023 V60 T8 PE
Has thanked: 1609 times
Been thanked: 4065 times
It's a dddrrrrrtttt sound
