So.... Was working on my brakes on my 850 today. After spending WAAAY too much time on them (Didn't have the right size Allen for the front, and one of my guide pins in the back wasn't cooperating), I went to finish with the back right tire. Lug nuts are on there WAY to tight. Tried some blaster, a breaker bar, and an pipe extension with a four-way. Only thing I did was twist the four way.
I'm currently thinking my only option is to take it somewhere and ask them if they can get the tire off, or at least loosen the lug nuts. Anything I can do at home before I go that route?
Oh, and as a side note, if you're ever working on the rear brakes of an 850, and those guide pins aren't coming quite so easily, one option is to chisel them into a couple pieces and replace them. AutoZone sells two-packs of the guide pins for $2.99
Lug Nuts too tight
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Good thing you didn't get a flat.
Take it to the tire place that did them in the first place and ask them if that's how tight they always do it. Lucky if your rotor is not warped because of it.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- Has thanked: 312 times
- Been thanked: 818 times
Any shop can break it loose, that's by far the easiest way to go.
You will so rarely run into this problem, especially if doing more repairs yourself now, I would not invest in any special tools just to break loose stuck lugs.
- Has thanked: 2209 times
+1 to what the guys say. Take it to a tire shop (ideally the one that fitted them last), punch the idiot that did it (joking of course!), and ask them to undo it and suggest if they have caused any damage you may seek restitution! I have an electric impact driver for this reason and it has saved me several times. Sure I have a 3/4" breaker bar and all that, but the electric wrench is way easier and I think is less likely to break the bolts as it kind of vibrates it loose rather than constant torque of a break bar wrench and socket.
When they are on that tight, it may only be an impact gun that may shift it. If it is an alloy rim, check it front and back near the bolt holes for damage and cracks. There is no reason in this day and age to do stupid stuff like this, but way too many sloppy 'pros' out there as I am finding.
I wish you luck.
I wish you luck.
ir637113
- Year and Model: 94 850 NA Wagon
- Has thanked: 12 times
Ended up taking it to a different shop. Had the tire done at Wal-Mart a year or two ago (I know, I know, but a $50 tire brand new is nice when you're young and broke). They were backed up with about an hour or two wait, and the shop next door said they'd do it for $10 and be done in about that many minutes.
Now I've got a REALLY cool issue. Got my brakes done, etc. and I've got a new noise coming from that tire. Sounds like maybe something is catching once per rotation. I'm thinking it might be a spot on the brake pad, or something similar. I'll give it a week and check it out. Any ideas?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I once had a shop undo the lugs on a new purchase with a ... 6ft breaker bar. And they hand trouble with that
Those were however plain steel wheels.
Had a youngin epoxy coat there wheels and installed them slightly not dry. After a good year of being installed they ended up needing some work done eventually.
The lugs + epoxy + over tightening = new hub wheel and hardware.
Glad they had money for that expensive lessen!
ugh smh 850 Turbo fridge
ir637113
Ouch...beigg wrote: 24 Apr 2017, 18:19 Had a youngin epoxy coat there wheels and installed them slightly not dry. After a good year of being installed they ended up needing some work done eventually.
Now the lug bolts have been removed, maybe it is worth jacking it up and having another look as you can get the wheel off it may be easier to identify the source.
Good luck!
Good luck!
- 1988 Views
Last post by jimmy57
- 1234 Views
Last post by tle1288
- 1131 Views
Last post by RussB
- 23 Replies
- 10678 Views
Last post by zupta82
- 1249 Views
Last post by packetfire
