My main reason for buying rims was to avoid the twice yearly charge of $65 for tire changing.
Is there a cheap but decent floor jack that i can use for a v70?
I understand bottle jacks probably won't fit underneath.
I saw a powerbuilt jack for about $60 not mixed reviews.
I will only be using it to change tires and maybe work on the lawn mower.
Decent but cheap floor / bottle jack
The aluminum Pittsburg brand racing jack is great for that job...do you guys get Harbor Freight up,North?
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Don't buy CHEAP tools!
Especially a jack.
Especially a jack.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- Been thanked: 504 times
In the US, I use the Harbor Freight 2-ton steel jack ($25) and works great.
After 1 year, it leaks externally, I replaced with a new O-ring and it is perfect now.
I posted the floor jack O-ring DIY in forum.
Since you are in Canada, go to Canadian Tire and get this floor jack, which is exactly the same as the harbor Freight 2-ton floor jack I have at home:
http://www.canadiantire.ca/en/pdp/certi ... p.html#srp
PS:
- Don't ever get under a car supported ONLY by a floor jack, use jack stands.
However, for the purpose of tire rotation, get the tires ready, jack the car up (chock the fore and aft portions of the tire on the other side of the car to prevent rolling), change the tires and done.
- If you ever need O-ring for that jack, send me a PM.
PS:
