Hello All,
I recently purchased a super clean '94 940 Turbo wagon with only 110k miles. Fixing little things here and there but the main thing that bothered me was the rear end sagging a little. After doing a lot of research I decided to replace the rear springs, shocks and trailing arm bushings. Unfortunately, this actually lowered the rear of the wagon 3-4 more inches so now it has an awful backward leaning stance (almost like a lowrider).
My wagon is a non-nivomat car with live axle setup and the H suspension code on the build plate under the hood.
I installed Lesjofors 6819405 HD springs from FCP Euro and they have confirmed this is supposed to be the correct part based on my VIN#.
Additional research online shows alternate part numbers like Lesjofors 307665/Part# 4295804 and also Lesjofors W0133-066-0300-LES for heavy duty rear wagon springs.
Can anyone assist with helping me find the correct spring that will level out my wagon? Any help is greatly appreciated.
Brandon
1994 940T Wagon- Rear Spring Help
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Part number shows up as 43615808 for 740/760/940/960 wagon rear spring. Look at this link for catalog:
www.kilensprings.com
1988 Volvo 760 Turbo Wagon
Thanks for the response. That part number you have is the equivalent of Volvo OE number 1273977 which is the rear spring for 940 sedans. I believe the sedan spring is about an inch shorter. There are so many suspension combination for these cars it's crazy. I used to have a 92 740 turbo wagon and replacing the springs with the HD wagon ones fixed the sag and raised it a few inches so I don't understand what's going on with my 940.
lummert
Kilen rear srings for 740/760/940/960
Kilen springs are made by Lesjofors.
For cars without self leveling 66090
Reinforced spring for cars without self leveling 66110 (Volvo 1359710, 12739777F)
Kilen 66210 (Lesjofors 42 058 04) is listed as cargo rear spring.
Kilen 66210 dimensions in mm
13.00 Dt (spring wire thickness?)
123 Dy (Diameter?)
375 L0 (Length?)
Kilen 66200 dimensions in mm
12.00 Dt
122 Dy
397 L0
123 Dy (Diameter?)
375 L0 (Length?)
12.00 Dt
122 Dy
397 L0
