98 v70xc boosting at 15 topping out at 20 psi.
Switchemlee
Year and Model: 1998 v70 xc awd
Post by Switchemlee »
What should my first step be to figure out whats wrong with it? Im using the torque app and the boost guage in there on my adndroid phone to find these readings. Is that accurate way to read boost?
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Someone correct me if I'm wrong, but there should be no way a stock (or even tuned) 98 V70XC can produce 15, let alone 20 lbs of boost. Highest I've seen on mine is about 7-8 I think (no tune) with an actual gauge.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Has thanked: 1611 times
Been thanked: 4074 times
ecbsykes wrote: 28 Apr 2017, 09:30 Someone correct me if I'm wrong, but there should be no way a stock (or even tuned) 98 V70XC can produce 15, let alone 20 lbs of boost. Highest I've seen on mine is about 7-8 I think (no tune) with an actual gauge.
Ssshh. You are spoiling a perfectly good $500 turbo upgrade app in the App Store with a guaranteed 15 psi of boost demonstrated.
Has thanked: 2210 times
Been thanked: 1852 times
I agree. There is no way a 13G should be producing that amount of boost. Less than 10 on the LPT motor, as the TCV Volvo use is only rated to 12 psi.
Has anyone played with the TBV rod and screwed the threads way up to increase boost (or engine detonation if not careful). I think the first thing is to get a proper gauge on the turbo to see if the app is close or way off.
Switchemlee
So i should install a proper ine furst to see if its accurate? Vould a vaccum leak produce high psi?
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Boost gauge.
85 GLH, 367 whp
00 Insight, 72 mpg
Switchemlee
Nice set up! Where can i get a proper boost guage for 98 v70xc? Ipd boost guage doesnt fit my car apparently
Switchemlee
I took my turbo actuator apart to test it. It seems to me that the diaphram in it is no good. It makes a squeaky noise when i pull the arm out and also doesnt open with any amount of pressure of air i put through it. Looking for a replacemnet one if anyone can help thanks a bunch
IPD carries an upgrade kit I have on my car , I'm sure the other vendors have stock replacements , too.
tryingbe
Post by tryingbe »
Switchemlee wrote: 28 Apr 2017, 17:41 Nice set up! Where can i get a proper boost guage for 98 v70xc? Ipd boost guage doesnt fit my car apparently
PM sent.
85 GLH, 367 whp
00 Insight, 72 mpg
