1999 V70 T5 M56 ELIZABETH 578465 Nautic Blue 417 Perfo 16 Wheels
Forum rules
Has thanked: 1611 times
Been thanked: 4072 times
Can seal installation tool thread here
https://www.matthewsvolvosite.com/forums ... 1&start=20
Visual Audible Tactile Hose Inspection here
viewtopic.php?f=1&t=79114&p=426011&hilit=vacuum#p426011
Replaced radiator with Nissens jan 15, 185000 miles
ABS still faulting on right rear wheel - ordered new rear harness from FCP
March Volvo fest
Cleaned relay terminals. Nasty
viewtopic.php?f=1&t=80481&hilit=Albany&start=20#p434364
186500
NEW Bosch single electrode spark plugs. Old ones worn to between 035 and 040, whitish
Last serviced at 167000 miles:
Running NGK Cu plugs with 27000 miles on them. Car was running well, but gap had grown to over 0.040 inches. Spec in manual is 0.030 inches and many here recommend 0.028.
I regapped to a tight 0.030" fit.
Thinking back I'm not sure I checked gap on plugs out of box, but that was in a long since overwritten piece of RAM
p80 bastard fuel pressure specs here
viewtopic.php?f=1&t=68182&p=362020&hili ... ed#p362020
apr 28 190250 Oil change 10W-30, filter change.
Crank and immobiliser sequence documented here
viewtopic.php?f=1&t=81535&p=444597#p444597
Front ABS Sensor connections documented here
viewtopic.php?f=1&t=82046
Thread with specs on both interior and exterior climate system sensor specs..
viewtopic.php?f=1&t=82671&p=449722#p449722
Replaced alternator and AC compressor to stop growl
Used Valeo AC 1999-2000 only. 3 hours labour
Right radiator mount hardware loose, zip tied and will repair
Replaced exhaust CVVT hub with used and retimed
viewtopic.php?f=1&t=83008&hilit=Cvvt+1999&start=10
197800
