I have a leak, I'm guessing the sunroof because when the car is parked on an angle where the driver side is lower than the passenger side it leaks. After a heavy rain there will be almost a half inch of water on the driver floor. When I start moving I can hear water above my head drain down the passenger side.
I've pulled both A pillar trim pieces an there's no tube. If it runs down the a pillar itself then I'm screwed.
If anyone has pics or a diagram that would be great.
Anyone have a diagram for the sunroof drain hoses for an 01?
ThommyKent
- Year and Model: 91 245 97 850 T5
- Been thanked: 5 times
The #32's are your drains hose locations. Just run a something like a coat hangar down them to unclog them.
download/file.php?id=4065&mode=view
Thanks, where to they drain to? Are the hoses in the frame itself?ThommyKent wrote: 30 Apr 2017, 16:24 The #32's are your drains hose locations. Just run a something like a coat hangar down them to unclog them.
2001 S80 T6 Moondust sent to auction for scrap
JDS60R
- Been thanked: 3 times
The front 2 go down the A-Pillar on both sides. The back 2 go into the quarter panel and out near the rear . Open the access panels on the side of the trunk and you will see them coming down the c pillar and connected to a black box and then another hose.
Retired
So they are inside the A pillar?JDS60R wrote: 30 Apr 2017, 16:34 The front 2 go down the A-Pillar on both sides. The back 2 go into the quarter panel and out near the rear . Open the access panels on the side of the trunk and you will see them coming down the c pillar and connected to a black box and then another hose.
JDS60R
front 2
from the corners of the moon roof ,under the headliner then through the a pillar , then through the body near where the fender meets the door. On s60 models the common leak is the drain being clogged at the corners of the moonroof itself.
Normal fix for s60 is to open moon roof fully, clean the drains with a vacuum and a little screw driver to clean out muck that is in there. Then slowly pour water there(front corner of moon roof) and flush out the tube.
Retired
I understand that, thanks. I'm trying to explain that there is no hose under the pillar covers.JDS60R wrote: 30 Apr 2017, 18:24 front 2
from the corners of the moon roof ,under the headliner then through the a pillar , then through the body near where the fender meets the door. On S60 models the common leak is the drain being clogged at the corners of the moonroof itself.
Normal fix for S60 is to open moon roof fully, clean the drains with a vacuum and a little screw driver to clean out muck that is in there. Then slowly pour water there(front corner of moon roof) and flush out the tube.
JDS60R
It is through the metal part . Look up , under the headliner to the moon roof . Then follow the tube down. You have to look through the holes in the a pillar to see it.
Retired
- 267 Views
Last post by jonesg
- 927 Views
Last post by rice240
- 2593 Views
Last post by legalstuff
- 1779 Views
Last post by erikv11
- 13 Replies
- 6057 Views
