This CV Joint Removal Tool used to cost $100 or so.
Now it is $20 on ebay with FREE shipping!
If you go to ebay and youtube and enter search terms "CV Joint Tool", you will see it.
This tool makes CV Joint work painless, no need for Vise, hammer, punch etc.
Of course you still have to spread the "C-clip" but that is all you have to do.
DIY: CV Joint Removal Tool anyone?
- Has thanked: 312 times
- Been thanked: 818 times
There are a bunch of these to choose from on eBay but choose carefully, make sure to get the tool that specifies the inner diameter is 100 mm, like the one cn90 showed a pic of.
Some ads say 100 mm, some say 95 mm, some don't say anything. Given that the turbo outer CV has 92 mm diameter, the 100 mm tool might be the best choice.
- Has thanked: 2210 times
I'm easily confused, so do you not have to open up the retaining clip with this tool or do they just forget to mention this in the video? I'm also assuming this to is to prevent the need to hammer the outer joint to remove it and also allow the job to be done without actually removing the axle from the car?
- Has thanked: 1611 times
- Been thanked: 4074 times
I've never ha d trouble getting a CV off a shaft
Getting the shaft out of the wheel hub is the trouble spot
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Good idea. I've always separated the inner joint, because it is easy just time consuming bending out the sheet metal skin.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- dyn blin
- Year and Model: 1997 850 Wgn
- Been thanked: 2 times
I had a humorous exchange with one of the ebay sellers:
I asked if the internal diameter was 100mm on the puller being sold, he quickly replied & said no, sorry- he measured it to 9.99cm.
I bought it.
I bought it.
'97 850 GLT Wagon- Driving to see 300k in the rearview
- Been thanked: 504 times
Ha,
Once you receive the tool, could you post a photo with measurements (just to confirm what they say) and also the name of the ebay seller?
Thanks!
Thanks!
- dyn blin
Will do, it's being shipped from NorCal, so I should have it shortly. I'll post up a pic with measurements.cn90 wrote: 28 Apr 2017, 18:37 Ha,
Thanks!
- 1197 Views
Last post by MoVolvos
- 18 Replies
- 9683 Views
Last post by Krons
- 4220 Views
Last post by ndphotonl
- 10 Replies
- 4849 Views
Last post by E Showell
- 11 Replies
- 3293 Views
Last post by theWIFES_S70
