I recently had my #3 injector fail electrically at 252k miles, so I purchased a used set of blues from a 99 C70 T5 with low miles, thinking they would be a direct upgrade.
To my dismay, I immediately noticed the "blues" do not have a second ridge in them for the fuel rail clip to hold.
I asked around and my problem seemed unique, since most people who have upgraded to blues seem to have done it on a M4.3 850 without the "fuel pulsation dampener" on the bottom of the rail, and the rail itself was fine without the clip. The early 98 4.4 fuel rail seems different than the rest.
The clip would not go on with the injectors fully seated on the rail. It is my understanding that the ME7 equipped T5's that these injectors came in have a more shallow spot for the injector to seat in, allowing them to be fully seated in the rail and the clip to hold the first ridge.
I wiggled the injectors up enough to get the clip in, noting that they aren't fully seated in the rail, but the car went back together with no issues and I have been closely monitoring for leaks to which I have none in 250 miles.
I'm still nervous about the injectors not fully being seated in the rail though- I thought about modifying the clip so it only holds the pulsation dampener, and seating the injectors fully in the rail, but I was wondering if anyone has ran into the same issue and could shed some light on it.
I've looked through countless posts and asked *shudders* Volvospeed to no avail... May as well ask the real Volvo forum
