On to the next problem of so many but, this one just popped up and a priority.
I'm getting a random misfire on one of the cylinders while driving, started yesterday. It happens in any condition, idle, driving or full throttle. It will come and go quickly on off like someone is flipping a switch an then not happen again for the rest of the trip, generally 10 miles. It usually happens after about 15 minutes of urban driving, no hwy. When it does misfire there is a sulfur smell which is the converter processing raw fuel I assume. There is also not much power loss when this happens aside from the missing cylinder if you get what I mean.
I'm not getting a CEL so I don't know what cylinder it is.
First things that come to mind are:
Coil
Plug(fouled)
Coil plug(all the retainer clips are broken)
Any hints to what might cause this? Is it common? I'd prefer not to randomly start replacing parts so I guess I need to drive it until I get a CEL?
Thoughts?
Random misfire-no CEL Topic is solved
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
Do you have a code reader? That could clarify things. My swag would be a coil that is starting to go. Love those Miss Intermittents.
- RSAmbassador
- Year and Model: 2006 S60 2.5T
Mine has same issue, but it threw a cel but for something totally different
I do, I bought an i906 a while back and I just figured if there's no CEL it won't tell me anything. I'll check it tomorrow.Cees Klumper wrote: 13 May 2017, 14:02 Do you have a code reader? That could clarify things. My swag would be a coil that is starting to go. Love those Miss Intermittents.
2001 S80 T6 Moondust sent to auction for scrap
What was the CEL for?RSAmbassador wrote: 13 May 2017, 14:05 Mine has same issue, but it threw a cel but for something totally different
- RSAmbassador
P0459, related to the evap system
- RSAmbassador
I think I might need one. But on a side note where is it at on the motor
On the fan shroud driver side.RSAmbassador wrote: 14 May 2017, 11:31 I think I might need one. But on a side note where is it at on the motor
Drove the car for about an hr, nothing. Five minutes from my driveway and it starts misfiring. This time the CEL flashed. It's still pretty random but now I have a place to look.
I'll keep updating, I'm going to take a look tomorrow after work when it's cold.
- 5560 Views
Last post by SwissXC90
- 1745 Views
Last post by freebirdchampion
- 551 Views
Last post by Seaway
- 1472 Views
Last post by terryjr
- 26 Replies
- 3406 Views
Last post by shiloh51933
