2000 S70 lit like a Christmas tree but no codes? Topic is solved
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
Well, I ordered a yellow sticker ETM off Ebay for $200 that had a build date of 2010 I believe and as soon as I plugged it in and turned the car on it ran horrible and I got the ETS light on. Re-installed the old one and car ran normal (as before) with no ETS light. Was able to take it on a 10 min. drive with a repeat of existing problems. Returning the used ETM. Going back to the power issue, the Alt test under full load at 13.7v and came back good. It will be a couple more paychecks to buy a new ETM. unhappy in VA
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
Have you measured the voltage drop on the B+ cable (the one from battery + to the fuse box)?
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
aaron1611
yes,13.51under full load
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Herb Goltz
Could be better-- the output is temperature and load dependent, but I'd like to see 13.7-14.1V. So where are you measuring the 13.5V? I'm curious what you see at the back of the alternator (the big red wire). These cars are notorious for bad battery and B+ cables.
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
aaron1611
sorry, Ive been out of town for work. I ended up getting a used/rebuilt ABS module online and it got rid off all my dash lights except the constant lit up arrow, Not flashing. The hesitation seems to be gone as well but I've not taken a long enough test drive to confirm. In terms of power, I'm getting 13.85 at alt., 13.55 at battery and 13.35 at the power box where the fuse's are under the hood.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
took a 20 min, test drive and no hesitation anymore. Tried rowing the gear selector about 2 dozen times but I still have the solid up arrow.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
I guess so far so good.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
That's still a lot of voltage drop, 0.5 volts?
Herb Goltz
Yeah, that's what I thought. I'll bet that the battery and B+ cables get plenty warm after a short drive-- mine did with a substantially smaller voltage drop. I'd replace them and clean all the grounds at the same time.
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- Has thanked: 2199 times
Take the cover off the main kidney shaped fuse box in front of the brake booster. Look at the brass colored nut at the front of that attached to the 'B+" cable. If it is not bright and shiny then it is failing. This issues affects 99/00 models most. When I removed mine it had totally melted and could easily have shorted to ground. When that happens the worst case is the car will light up!
After replacing the car started more easily and didn't crank as hard.
- 1450 Views
Last post by oragex
- 675 Views
Last post by jreed
- 1404 Views
- 1047 Views
Last post by shiloh51933
- 10 Replies
- 2687 Views
Last post by erikv11
