2004 XC 70 Purchase
PKulas
Year and Model: 2004 XC70
Post by PKulas »
I'm considering buying a 2004 XC70 with 98k miles.
Clean no accident carfax with regular scheduled maintenance performed.
Recent work includes cabin air filter, plugs, power steering change, new tires, front/read pads.
What other items should be coming due ? Timing belt? engine mounts?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Well, that's bad right there.
These cars (and most AWD cars) need ALL FOUR tires changed at the same time unless the other two are near new.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Don't worry about engine mounts, not that expensive.
As above, AWD is the most important check on these. You'll need to google up about the issues with collar sleeve failure and DEM corrosion (check Images on google). It has new tires so no worries but keep in mind, on these always have all 4 tires with same wear or the AWD gets damaged. Same when having a flat and using the spare donut.
Has thanked: 1611 times
Been thanked: 4071 times
Don't put a lot of faith in car faxes
A proper, pro Prepurchase inspection is better
John65
Year and Model: V70 2002, 2005 XC70
Post by John65 »
Timing belt is due around 105k miles. About $500-$700 item depending on who does it.
