1997 S90/960 B6304S, Misfire on 4&5 only. Topic is solved
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
The first question on my mind is why 4&5 only.
Active
Past
RickHaleParker
Sprayed from the down side stream side of the Mass Airflow sensor to throttle body and every other hose and connector I could find on the "tree" with Ether, no leaks detected. I'll get another can with a tube and try getting the under side around 4 & 5 better.
Active
Past
RickHaleParker
Took a can of Ether with a tube and hit the underside good. Still no detectable leaks.
Active
Past
RickHaleParker
Previous owner got the coil pack wiring harness switched on 4 & 5. Corrected, problem solved.
Active
Past
RickHaleParker
Recommendation: Before discontinuing the harness from the coil packs, mark the harness connectors 1,2,3,4,5,6. to avoid making the same mistake.
Active
Past
