MIJ's new $300 S70
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Looking good so far! Can't wait to see how the paint turns out!
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Thanks for the positive words everyone!
I'm hoping that the humidity settles down and goes below 50% today. If it does, this guy is getting painted!!
I got these tablets from a detailing guy that you put in a cup of water and leave in your car overnight to take smells out of the car.
Sure enough, I woke up this morning to go check and there is no more smoking smell in the car!!
Now, the only thing left (which I noticed when driving the car yesterday) is the A/C...gets warm after about 15 mins. Checked the pressure and it's fine.
I know what it is- the compressor clutch...so I now have several bread bag clips and will need to review how to use these to shim the clutch.
After this, I think the car is ready to go!!
MadeInJapan
I just tested the gap and it's right at 0.03, and not much I can close the gap, even with a screwdriver. So, for laughs and giggles, I tested the psi in the system...with it running I'm right at 24...so I add a can, and I'm only up to 26...hmmm... It's not hot here right now...a comfy 68 degrees outside. I think I'll go buy another can of R-134A and see if this takes care of it. I'm thinking the AC compressor does not need to be shimmed- I'm just low on gas. Of course, who knows if this A/C will hold pressure but for it to have held 24 in it, I'm thinking it does. Things do concern me though that adding a can only lifted the PSI's by 2 PSI...Thinking out loud here. I'm gonna go to the Big Lots here and buy more gas and some small zip ties too just in case.
MadeInJapan
A/C problem appears to be solved!! The pressure was just too low...added another can and it seems to be holding steady at almost 28psi now...it hasn't been that hot so I think that's good.
Other issue is it's rained, and rained and rained...I await a day that the humidity is below 50% so I can finally paint the roof!!
MadeInJapan
So, I prepped and attempted to paint the roof just over a week ago. I had painted the bumpers where they were peeling too so I was concerned that I might not have enough paint to do the job. Sure enough, I didn't. So, I reordered paint immediately and it came while I was away from town. Again, there's been rain so I can't do much else until humidity subsides. In the meantime, the family and I are off to the beach for a week. Will wet sand and finish up the roof when I get back from the beach. Just thought I would add a picture of the roof so far:
I'll have an entire can of paint to devote to the roof and then I think I'm finished with this car!!
Has thanked: 2200 times
Been thanked: 1852 times
I tackled the front bumper but ran out of the 2 part clear coat and the supplier was out of stock. Not entirely happy with the finish but maybe when I get back from vacation some wet sanding and buffing/polishing may improve the finish a bit.
Looking good on your project and good luck with the next can finishing it off!
MadeInJapan
Thanks Neil.
MadeInJapan
So, I've been in and out of town all summer and a de-masting of my sailboat and having to work on getting that repaired (sheathing the mast by welding airplane aluminum around the break) has kept me from this project, but then I got a call asking if I was still interested in selling this S70. I prepped and painted (finally) the roof of the car over the last several days. I kept waiting for a day where humidity was under 50% and it finally came on Monday. So, I got the roof finished. It's an okay job- tried to clean and then wax the roof afterwards but not really happy with the results. The wax didn't seem to all come off and left a oxidized look. With elbow grease that comes off too but hard work with buffing. Any suggestions here? should I "degrease" and use some different wax? I went with the traditional Turtle wax in a coaster looking container. Also, after the young lady came over to look at the car, we went for a test drive...all was good until the AC quit working after about 10 mins on the road. I came home and shimmed the clutch plate with bread clips and super glued them in place. I think this solved the problem (finger's crossed). So, I'm uploading a couple of pictures of when I painted the roof- first one is the prep and second is the outcome, for what it's worth.
Prepping to Paint.JPG (174.23 KiB) Viewed 1412 times
Maybe you waxed it before it was fully dry. I am no paint expert, but unless you dry it in an oven, I'd leave it for a couple of weeks before trying to wax a new paint job.
As to sorting it, I'm not sure what to suggest as any normal cleaner/chemical may make it worse. Need someone with paint knowledge who may know the answer. bmdubya1198 if I recall did some paintwork on his car. Maybe he will chip in?
Only other suggestion would be to try a buffing mop to see if you can buff it off rather than elbow grease?
bmdubya1198
I left my paint for a week or two before waxing it. Within a couple days I sanded and compounded/polished it, then I went over it again about a week and a half later and waxed it.
To degrease it, the only thing I can think of that MIGHT be gentle enough for fresh paint is dish soap. You would have to be careful with what you use on it, obviously.
