Can't get back window to roll up on my 1998 V70
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Before anyone starts tearing up the window motors,
it's worth keeping in mind that if the motor works
one way, but not the other, then the motor is OK.
99.9 times out of 100, the switches are the problem.
Been thanked: 4065 times
Can you do a quick test of switches by swapping connectors or are they keyed to the right one? I forgot from when I did my window switch replacement.
Has thanked: 2199 times
Been thanked: 1852 times
I seem to recall you can swap them over from side to side on the master switch. Not sure about the rear door switches though.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
remove the switch and clean it with contact cleaner or WD40, I had the same issue.
Then cycle it back and forth until it works.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
