They all do this. If you take it apart, you'll see why. I even installed adjusting links (https://www.fcpeuro.com/Volvo-parts/XC7 ... ting-Screw), it held it for about a months, and now the slack is back on.
Also, as already stated, it's a very good idea to check for delaminated pads. They do it after 10-12 years.
03 V70 Parking Brake - How much movement ( Answer: None) is OK? Topic is solved
- Botbasher
- Year and Model: 98 "R" & 03 T5 V70
- Been thanked: 4 times
Yeah... that's what I was thinking!!! OK, so I'll get some pads and find some JY adjusters (with all applicable hardware coming home in the bag!!vtl wrote: 05 Jun 2017, 10:24 They all do this. If you take it apart, you'll see why. I even installed adjusting links (https://www.fcpeuro.com/Volvo-parts/XC7 ... ting-Screw), it held it for about a months, and now the slack is back on.
So before I get into it... what causes the slack? just wear between the bits? I've done shoes before, but never had them so sloppy and rotate to the degree that these are. If it were my actual brakes (not parking), I'd be upgrading to discs ASAP!
K "needing a new pair of shoes" S
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
The parking brake mechanism raises only one side of shoes, the other one is not touching the drum at all. Add to that allowed horizontal movement of shoe and you have that 10-15 degrees slack.Botbasher wrote: 05 Jun 2017, 10:32So before I get into it... what causes the slack? just wear between the bits? I've done shoes before, but never had them so sloppy and rotate to the degree that these are. If it were my actual brakes (not parking), I'd be upgrading to discs ASAP!
The idea behind adjusting link is to reduce gap between the other, non-touching end of shoe and the drum, so the contact surface becomes larger and the shoes allow less horizontal movement in the slot, where the spring goes in, but that is not a complete answer to the problem. I have all the new parts in rear brakes, even hardware and springs, and the slack is again here.
Just a lousy design that Volvo did not manage to solve in years after multiple attempts. I use parking brake every day, when parking uphill I first put gearbox in N, raise parking brake lever, slowly release brake pedal then put gearbox in P. This way the g-box is not shocked.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
I think I figgered this out.Botbasher wrote: 05 Jun 2017, 10:32
With rear wheels in the air and handbrake applied, the brake disk is locked to the axle, but the axle can rotate (because wheels are in the air).
So what you're experiencing is the normal play in the gear train until encountering the transmission lock pin.
Your ebrake is good.
- Botbasher
Bzzzzzzzzzzzzzzz Tell him what he hasn't won today Don Pardo!!!jonesg wrote: 05 Jun 2017, 16:39I think I figgered this out.Botbasher wrote: 05 Jun 2017, 10:32
Has nothing to do with the front wheels.... That was just an example of the level of slop in the E-Brake!!
Thanks for playing!!
K "tossing no stones" S
vtl
Parking shoes are attached to a dust shield, which is attached to a wheel hub, which is indirectly attached to car's chassis. With shoes properly holding the drum (and every other bit in parking brake mechanism working well) there should be no movement.jonesg wrote: 05 Jun 2017, 16:39 I think I figgered this out.
- jonesg
vtl wrote: 05 Jun 2017, 19:14Parking shoes are attached to a dust shield, which is attached to a wheel hub, which is indirectly attached to car's chassis. With shoes properly holding the drum (and every other bit in parking brake mechanism working well) there should be no movement.jonesg wrote: 05 Jun 2017, 16:39 I think I figgered this out.
As long as the rear wheels are on the ground that is true.
But his rear wheels were in the air.
- Botbasher
You beat me to it... had to drive to work! Shucks!!
You are asking here if you have issues??My 98 is similar in action, so that's why I am wondering if I have an issue... or if this is just the norm?!?
Ciao!
K "unlucky in pairs?" S
My 1999 and 2005 both lock up with no rotation after I apply the hand-emergency-e-parking brake FWIW.
Bring it up to ALB and we will get you setup and Ill throw in a free NY inspection - they actually have to put the car up and remove a wheel here.
