Volvo C70 2004 intermittent lagging/unresponsive.
zpsny91
Year and Model: 2004 C70 2.3 Turbo
Post by zpsny91 »
abscate wrote: 07 Jun 2017, 05:18 These cars are too complex to diagnose by symptom, especially when they are spurious.
You have pretty much covered the ignition troubleshooting with coils and plugs ( yeah ME7) so start with getting fuel pressure monitored at the rail. You can sacrifice a tire pressure gauge to read this. If the pressure is marginal, the suspects are
Fuel pump relay
Fuel pump
Fuel filter
In that order.
Rented out a fuel pressure test kit. I'm assuming the gauge is broken, no readings. Will have to try again with another guage. I'm a little skeptical though, as a lot of the problems I relate to fuel pump aren't happening, like stalling/dieing at stops or difficulty starting.
zpsny91
Post by zpsny91 »
Fuel pump relay
Fuel pump
Fuel filter
In that order.
I clearly do not know how to use this gauge. I am getting no reading when I hook it up and start the car. The car is running so I should definitely be getting something. I'm sure I'm using the right adapter.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Finally read your post after our PM's back and forth. Funny but I also thought about the throttlebody cleaning. These cars need to be done every 70 - 80,000 miles or so. Did you try taking it off and cleaning it? If so did that make a difference?
Has thanked: 1611 times
Been thanked: 4074 times
Can one of the experts chime in on when the c70 series switched from MM to Denso orvBosch throttle body?
I thought it was MY 2002
