It's the spring seat you that is the first of the cheap parts to fail, and typically squeaks like you describe (I think!). You can check at the the top nut, put a big wrench or pliers on there and gently rotate. If there resistance, the rubber is intact. But if you can turn it, the rubber has torn through and the spring seat is shot.
Strut mounts get creaky when the bearings dry out or fail. There is no definitive test but if you have someone turn the wheel left and right (best to park on slick cement) while you are looking at the mount from the top, you can see a really bad one will stutter and creak.
Meyle HD Control Arm Bushings, hydraulic?
- Has thanked: 311 times
- Been thanked: 817 times
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
So I tried to twist the upper cap to see if there's any movement. Nothing. It's still pretty tight.
So I don't think that's the case... Will definitely try to set a camera low to the ground so I can record the sound.
Thanks guys.
Thanks guys.
Retired:
2015 Volvo S60, T5, 85K
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It requires quite a lot of force,not just twist it easily.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
By hand it seems like a lot of force too twist it, but with a big wrench it moves easily - start to rotate it, you will either feel resistance or not. I said gently just because you don't want to shred the spring seat if it's not already broken. I wouldn't rely on testing by hand (unless it is so bad it just spins easily), get a tool on there.
- theWIFES_S70
thanks guys, I'll get some channellocks on it and report back... sigh, this sound has me so bummed!
Retired:
- 2975 Views
Last post by 800artfreed
- 441 Views
Last post by alschnertz
- 13342 Views
Last post by MarcM
- 31 Replies
- 9601 Views
Last post by vtl
- 1181 Views
Last post by cuhfs
