Volvo Radio From hu603 To hu803..?
1bigb1
Year and Model: V40 D2 2013
Post by 1bigb1 »
Can I change from a Volvo Radio hu 603 to an hu 803 ?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You mean HU 613, there is no 603 radio
You will need to buy the underseat amp and harness, otherwise it's an easy swap
The 803 runs off a 300 watt underseat amp, the center channel works off the radio.
Oh, you will also need the center dash speaker, the wires (harness) that goes from the speaker to the 803 is built in all these cars, so no worries there.
If you successfully do this, you will probably want to add better aftermarket door speakers as now it will pack a pretty good wallop and if turned up it will easily overpower the OEM speakers!
1bigb1
Post by 1bigb1 »
NO No , I have a HU603 in my Volvo V70xc and I would like to know if I could change / upgrade it to the HU803,if the connector plug is the same and what changes do I need to do if so..????
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
What do you want from HU803? Yours have a decent sound (can tweak equalizer, there's a hidden menu in radio), aftermarket MP3 CD-changer emulators are also available.
1bigb1
Post by 1bigb1 »
thank you
1bigb1
Post by 1bigb1 »
after market MP3 Cd changer emulators in South Africa are VERY VERY expensive
vtl
Post by vtl »
Buy one directly from China (ebay, aliexpress).
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
1bigb1 wrote: 13 Jun 2017, 23:40 NO No , I have a HU603 in my Volvo V70xc and I would like to know if I could change / upgrade it to the HU803,if the connector plug is the same and what changes do I need to do if so..????
JRL told you the exact changes you have to do, I'm not sure what wasn't clear? You have to do that if you want the HU-803 to work. The HU-803 won't work without an amp. As for the connectors, behind the radio there is a grey connector hidden somewhere wrapped in a white foam, this will connect to the grey plug coming from the amp harness, then the green plug will go into the back of the radio. Then the DIN connector from the amp goes as well into the back of the radio.
1bigb1
Post by 1bigb1 »
thank you
db130
Year and Model: 2002 V70 T5
Post by db130 »
You can use either the PA-200 (the 200 watt amplifier) or the PA-300 (300w) for the HU-803.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
