2006 xc70 Handling Issue
stoutlogic
Year and Model: 2006 XC70
Been thanked: 4 times
Post by stoutlogic »
My Xc70 feels like the car is controlling the steering around corners, meaning it feels as if the steering wheel is trying to move itself back and forth when I turn. I notice it mainly on longer sweeping turns. Doesn't feel like anything is loose but feels as if something is powering the steering wheel side to side. Makes the car feel unstable, kind of like driving a boat.
I have installed new inner and out tierod ends, checked the wheel bearings and ball joints, also did a proper 4 wheel alignment. Control arms seem fine. No play in any parts that I can tell. Struts and steering rack appear fine too.
Could this be something electric based that is controlling the steering rack? Maybe something in the steering linkage to the rack?
Thoughts?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
on my 04 v70 its the control arms when it feels vague on the steering, slight side to side drift on hiway.
With car raised, weight of the wheel pulling the strut down I can see rips in the rubber bushing.
stoutlogic
Ill give them a second peep but they looked fine when I had the car up on the lift. They were dealer replaced around 100k. 140k on the clock now.
jonesg
Post by jonesg »
Yeh so its probably something else. Check tire pressure too, that can do funny things if one is low. Rear wheels too.
stoutlogic
IT feels like the car is actively trying to turn the steering wheel. IDK if it could be the steering angle sensor or yaw sensor, or something else?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
What your proper aligned angles are? It looks like wrong angles are listed in database for Hunter alignment rack.
Also check that rear suspension is in tact too.
user17600
Year and Model: V70A, 04; XC70, 06
Post by user17600 »
The wife's 06 had the same issue. Turns out some PO had changed the fluid and put the wrong kind in.
Had the indie flush it twice and it is 90% better, still pulses a bit most noticeably on long left curves.
stoutlogic
Thanks. Wrong angles in hunter rack database? That's strange. I did check the rear suspension at the time I did the 4 wheel alignment.
By fluid I'm assuming the wrong type of power steering fluid? Ill take a look.
Thanks for everyone input!
stoutlogic
Going to flush the power steering rack with new fluid. Current fluid is nasty brown. I'll report back with results
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
Fluid shouldn't be brown, needs to be a clean green. A good flush is needed. Hope this is your solution.
