Rear view mirror replacement
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
(2001 V70 T5) I have a defective automatic rear view mirror. I've checked out the vids on replacing the glass only, how to separate the old mirror from the circuit board and transfer the CB to the new mirror, etc... I can get the glass from a parts yard, and there is one question I could use an answer to:
When I go to pull the part from the donor car, can I simply separate the front and back of the rear view mirror housing, then unplug the circuit board, instead of removing the entire assembly? It looks like all I need to do is to insert a screwdriver between the two pieces and pop it apart..
Thanks in advance...
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
See post below
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
If your 2001 has a separate key you can ask the wrecking yard if they have a working remote fob to match that donor car. If so simply swap BOTH fob and mirror as an entire assembly.
Saves time and frustration.
azureblue
Post by azureblue »
thanks for the tip, but the donor car didn't have any keys. It would be much easier to change the fob than the circuit board in the mirror, for sure.
Besides, my fob quit working when I changed it's battery. Next on the list....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
yagger
Year and Model: V60 2016
Has thanked: 6 times
Been thanked: 39 times
Post by yagger »
Actually, there are methods for transfer data from old (original) mirror to replacement. And, there is way for reset used remote control also, and program it to mirror like new remote control.
azureblue
Post by azureblue »
could you tell me / refer me to how to do that?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Botbasher
Year and Model: 98 "R" & 03 T5 V70
Been thanked: 4 times
Post by Botbasher »
You need the special Yagger magic!!! The man has skillz!!!
+1 for anything dealing with him!!
KS
Never become a pessimist. A pessimist is correct oftener than an optimist, but an optimist has more fun, and neither can stop the march of events.-Heinlein
We have met the enemy and he is us.-Pogo
If speed kills, do brakes give life??
azureblue
Post by azureblue »
yeah, I know. He did some serious magic on my ECU....
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
darylrobert
Year and Model: V70 240 740t xc70
Been thanked: 44 times
Post by darylrobert »
I'm repairing mine at the moment, yes to get the casing apart you pry but your arms will pain, much easier to remove the whole mirroe and light as a unit. however dont pry the mirror off use a long blade
azureblue
Post by azureblue »
Thanks. I was lucky enough when I went to the parts yard to find the mirror assembly already removed from the donor car. Thanks for the caveat about not using a long blade to remove the donor mirror. I hope today I can take apart the donor rear view mirror assembly..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
