97 850 Different Front axles for standard?
dairyqueen814
Year and Model: 1997 855 NA
Post by dairyqueen814 »
Hi guys
I'm on eEuroparts right now and looking at this https://www.eeuroparts.com/Parts/73794/ ... e-A807802/
It specifically says it's for an automatic transmission. But when I was doing my manual swap, the old axle from my automatic fit right in. Can anyone confirm that they are the same for both transmissions? I'd rather not wait 15 days for the IPD one to ship. Thanks!
1994 850 Sedan NA Black, 343,000mi - Crashed and parted
1993 850 Sedan NA Red, 240,000mi - Now my little brother's car
1994 850 Wagon NA White, 251,222mi - Sold
1997 850 Wagon NA Red, 105,000mi - Currently my pride and joy
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
From factory, manual axles are THICKER than automatically axles. HOWEVER, you can use auto axles in manual cars or vice versa.
85 GLH, 367 whp
00 Insight, 72 mpg
dairyqueen814
tryingbe wrote: 19 Jun 2017, 13:04 From factory, manual axles are THICKER than automatically axles. HOWEVER, you can use auto axles in manual cars or vice versa.
So I can just plug and play without a worry in the world? Thanks!
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
You might want to order an automatic axle seal as well if the manual axles are thicker in diameter. It's easier to change both at once than have to go back and remove the axle again to change out the seal if a leak starts. I still need to replace one of my seals.
tryingbe
Post by tryingbe »
bmdubya1198 wrote: 19 Jun 2017, 15:41 You might want to order an automatic axle seal as well if the manual axles are thicker in diameter. It's easier to change both at once than have to go back and remove the axle again to change out the seal if a leak starts. I still need to replace one of my seals.
Please don't spared rumors.
85 GLH, 367 whp
00 Insight, 72 mpg
tryingbe
Post by tryingbe »
dairyqueen814 wrote: 19 Jun 2017, 15:20
Yes.
https://ozvolvo.org/discussion/1714/850-v70-axles
85 GLH, 367 whp
00 Insight, 72 mpg
bmdubya1198
tryingbe wrote: 19 Jun 2017, 17:40
So the automatic and manual axle seals are the same? They look slightly different in pictures (the manual one actually looks thicker). Sorry, I was just adding a thought since it seemed to make sense.
Nevermind, just checked out that link, makes sense now. I thought you meant the whole shaft was a different diameter, not just the axle itself.
skloon
Year and Model: 94 850 95 850 04 S60
Post by skloon »
I have used the same axles in automatic, manual turbo, 10 valve and 20 valve cars, there are differences in the shaft diameter but the two ends and support bearing are the same as is the seal facing- I suspect that if not already all the 'new' axles are the same, built to the lowest price pont
