V70 suspension sequence
woodycaldercloggs
Year and Model: v70 1998
Has thanked: 23 times
Post by woodycaldercloggs »
I have a 1997 Volvo V70 turbo and intend to change the struts, control arms, outer tie rods and control links this weekend. Does anyone know the best and easiest sequence in which to do this work?
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
After removing old components tie rod, control arm, strut then sway bar link. I would also change out the inner tie rod and boot.
woodycaldercloggs
There is no vertical play in the wheels and the boots seem ok.
Is there any preferred sequence when doing these jobs?
Has thanked: 312 times
Been thanked: 818 times
You don't want the control arm and the strut to both be off at the same time, or the big steering knuckle will flop around too much. Here's the sequence I would use:
(0) Try to break free the cinch nut on tie rod. Soak with quality penetrant, use heat, get it broken loose in advance then re-tighten it.
(1) Old strut out, new strut in, but do not reconnect the sway bar end link when you are reinstalling.
(2) Remove old end link
(3) Remove and replace tie rod(s)
(4) Remove and replace control arm (drop at subframe first, then open at pinch bolt to remove completely)
(5) Install new end link
You can do all of this without removing the brake caliper, I know I would, but you may want to take it off and secure it to the coil spring to get it out of the way.
woodycaldercloggs
That all sounds pretty good.
Many thanks
