Check the rear rotor size, you may well find they are the same. Finding parts for the earlier rear brakes are usually easier than the later ones. Sorry to see the end of a good car I know you put a lot of time into. It sucks.
I liked the 98 V70XC we had, and was my son's first car. He loved that car and now drives our 06 XC70. Just had him drive my 2000 V70 NA SE so I could try to figure out where the annoying rear door/upholstery squeaking was coming from. He commented when we return he had forgotten how nice the P80 was to drive.
Always good when you can find a good lower mileage car with hopefully fewer bodges to run. Good luck!
A Deer killed my Beautiful 2000 V70XC /SE
- Has thanked: 2200 times
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
Shiloh,
The rear seats on the SE have booster seats, IIRC. You might want to swap them out if the interior is the same color.
Yes, you do want the newer calipers from the '00'.
How about the radio?
Klaus
bskeels
- Year and Model: 1997 Volvo 960
- Been thanked: 3 times
The awd cars have calipers similar to the fronts, the fwd use the pin style in the rear
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
2012 Ram 2500
97 Volvo 960
08 Volvo V50 T5
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
How fast were you going when you hit the deer? Looks more like you hit a moose. I nailed a deer at 55mph in a Subaru forester, and all it cost me was a new fender, headlight, grill piece, and some dents in the hood.
Knows enough to be dangerous
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
only took one to do the damageabscate wrote: 01 Jul 2017, 13:01 If that frame isn't bent, I think I would call Erie for matching color parts and put it back together
Hopefully for not too many bucks..
Current Volvos:
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I've had my front fascia off a couple times and have noted it doesn't look particularly strong to resist damage to the cooler pancake--I was specifically thinking a deer hit centered higher on the grille would likely disable the car. And the slope of the front end isn't such that it would bounce up and over the top of the vehicle like what happened when I hit one with a 80s-something Taurus some years ago. It didn't do much damage to the Taurus - sort of dented the front 16 inches of the hood and blew a headlamp bulb. It bounced up in the air and I went under it - not touching the car anywhere else. The car was still perfectly drivable. Headlamps on the Taurus were disgusting awful - I think I saw it with about 1 second to react so I would have been going about 55-60.WhatAmIDoing wrote: 04 Jul 2017, 15:36 How fast were you going when you hit the deer? Looks more like you hit a moose. I nailed a deer at 55mph in a Subaru forester, and all it cost me was a new fender, headlight, grill piece, and some dents in the hood.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
Yes I actually use the factory booster seats with my son, he loves them because he doesn't have to in the regular booster seat. The 2000 V70XC /se had the 3rd row seating as well. Everything is same color...interior and exterior. The SE variant of the XC came w/more wood grain (steering wheel, shift knob).Klausc wrote: 01 Jul 2017, 17:54 Shiloh,
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- shiloh51933
I was doing 70mph & couldn't possibly stop so I drove through the family of deer as they ran into the hwy from the median. I actually stepped on the throttle to plow through, it worked I guess because I'm still here. Anyway the radiator, intercooler and condensor are all crushed. Fan is crushed along w/headlights, turbo plumbing, oil dip stick, oil cooler lines, atf cooler lines, ect..mrbrian200 wrote: 04 Jul 2017, 22:35I've had my front fascia off a couple times and have noted it doesn't look particularly strong to resist damage to the cooler pancake--I was specifically thinking a deer hit centered higher on the grille would likely disable the car. And the slope of the front end isn't such that it would bounce up and over the top of the vehicle like what happened when I hit one with a 80s-something Taurus some years ago. It didn't do much damage to the Taurus - sort of dented the front 16 inches of the hood and blew a headlamp bulb. It bounced up in the air and I went under it - not touching the car anywhere else. The car was still perfectly drivable. Headlamps on the Taurus were disgusting awful - I think I saw it with about 1 second to react so I would have been going about 55-60.WhatAmIDoing wrote: 04 Jul 2017, 15:36 How fast were you going when you hit the deer? Looks more like you hit a moose. I nailed a deer at 55mph in a Subaru forester, and all it cost me was a new fender, headlight, grill piece, and some dents in the hood.
I got a '98 w/literally 100, 421 miles on odo. It's it really good shape considering year, it did need new a/c compressor, accumulator, headlight reflectors wore away so I'm replacing them and one rim was bent but I just happened to have a matching rim from a '98 V70XC I had a few yearsback.
- 1313 Views
Last post by bmdubya1198
- 961 Views
Last post by Flytrapper
- 1716 Views
- 811 Views
Last post by c70_lindsay
- 1705 Views
Last post by oragex
