94 850 Turbo running rich and idling high
Vazfx16
- Year and Model: 1994 850 turbo
- Been thanked: 2 times
The sensor is (if you are facing the car), left side, to the left of the intake manifold and to the right of the pullies . It is connected into the thermostat housing. In my situation, the plug's internal bullet connectors where not seating properly. The plastic plug with click into place as it should, but internally the bullet connectors were not making good contact. I pulled the bullet out a bit (with out damaging the thing wires), and plugged them into the female connector. Then I connected the plastic part of the connector. Everything was better instantly.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You can't without draining coolant a bit.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Vazfx16
Correct. Drain about a liter or so out. Just enough so that there is no coolant in the upper radiator hose. YOu will have to then move that hose out of the way. Undoing it from the thermos housing
Park up hill on a curb, then point the hose to the sky as soon as it's off? That should work rather than fussing with coolant.
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
So what you're saying, really, is that the rear o2 sensor doesn't actually do anything at all, since you can simply disconnect it, and all that happens is a CEL, and that it's only a source of potential problems? That seems very, VERY dubious to me.misha wrote: 30 Jun 2017, 04:23 Yes....IF it is dead and you leave it connected.It gives false reading,almost like bad Maf.
If you disconnect it's connector...all you get is check engine light.
Trust me,i've tried it numerous of times on Volvos and other cars with success.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- misha
What would you say on this...my friend drives a car for two years just on Rear o2 sensor which is in it's rear position,connected to a Front o2 connector and cat removed?!Rear o2 plug is disconnected.
Besides check engine light and code for a rear 02 sensor,there is no other codes.
If you have doubts try it,but you would need to remove cat.Otherwise your engine would running lean.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
It does, but is correct.Sommerfeldt wrote: 05 Jul 2017, 00:29So what you're saying, really, is that the rear o2 sensor doesn't actually do anything at all, since you can simply disconnect it, and all that happens is a CEL, and that it's only a source of potential problems? That seems very, VERY dubious to me.misha wrote: 30 Jun 2017, 04:23 Yes....IF it is dead and you leave it connected.It gives false reading,almost like bad Maf.
- S
The rear sensor just checks the exhaust fro oxygen content after the catalytic converter and reports to the ECU AIF the cat is doing a good job. The ECU does nothing with this information, it only uses the front O2 sensor to monitor and adjust the fuel deliverd ( it uses other things too) If the rear O2 sensor reports out of range, the ECU sets the Low cat efficiency CEL
Sommerfeldt
This makes little sense to me - if this was accurate, then a dead, dying or faulty rear 02 shouldn't have any effect at all (besides a CEL). It certainly should not have made a great big rich condition when mine went out. There's a flaw in your arguments, gentlemen.abscate wrote: 05 Jul 2017, 05:07 It does, but is correct.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- 14 Replies
- 3137 Views
Last post by Kuhnboy
- 813 Views
Last post by misha
- 9 Replies
- 1919 Views
Last post by warmblood58
- 442 Views
Last post by classical
- 266 Views
Last post by grottu
