NO DAMAGE had is checked today and the mechanic pointed to the wheel arch and said 'it was a big hit' you can see that the tyre hit the wheel lining. The clunking noise however was the sway bar moved all the way to one side causing it to knock against something i think it was a link rod. He showed me how it easily moves left and right about 2 inches or more..
pothole breaks xc70 Topic is solved
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
- Year and Model: Lots
- Been thanked: 128 times
Open up the spring assembly and check your bump stops. They can erode and become very squishy resulting in what you have there. Good bump stops won't allow contact between tyre and body.
I just replaced mine in my 2001 T5. They were about 1/3 shorter than when new and looked a real mess.
I used the Monroe kit which isn't an exact fit however some shaving down with a grinder made them fit the seating washers.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
errant post
- 2469 Views
Last post by Clemens
- 1388 Views
Last post by callahanoffroad
- 1532 Views
Last post by s2zeller
- 725 Views
Last post by xc90surfer3
- 680 Views
Last post by ndphotonl
