pothole breaks xc70 Topic is solved
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 42 times
Re: pothole breaks XC70
Post by darylrobert »
NO DAMAGE had is checked today and the mechanic pointed to the wheel arch and said 'it was a big hit' you can see that the tyre hit the wheel lining. The clunking noise however was the sway bar moved all the way to one side causing it to knock against something i think it was a link rod. He showed me how it easily moves left and right about 2 inches or more..
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
duct tape will fix that.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Open up the spring assembly and check your bump stops. They can erode and become very squishy resulting in what you have there. Good bump stops won't allow contact between tyre and body.
I just replaced mine in my 2001 T5. They were about 1/3 shorter than when new and looked a real mess.
I used the Monroe kit which isn't an exact fit however some shaving down with a grinder made them fit the seating washers.
Georgeandkira
Has thanked: 64 times
Been thanked: 69 times
Post by Georgeandkira »
errant post
