Made this from old upper mount and crossbar
All I did was drill a hole in each and add a long bolt, holding it up right now
Engine Support lift
Sweet!!
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 79 times
- Been thanked: 71 times
Plus--you removed the rubber so a nut could go on the bolt (you didn't tap the hole in the mount). Got it.
When do you need this function?
Transmission removal is the most common, also replacing lower engine mounts/subframe dampers.
- 861 Views
Last post by ToyoToyo
- 1109 Views
Last post by SuperHerman
- 2199 Views
Last post by kallekula
- 13 Replies
- 2197 Views
- 846 Views
