I've mentioned this before, and I'll guess that as the metal heats and expands
the crack/leak closes up a bit. Seems to be coming from under the dash or even
a bit lower, hard to tell really.
I just put the car up on car ramps to do the transmission seal, and took a look.
I don't see any carbon traces anywhere. I see the flex pipe and the lower
flange, how does the top side connect?
Header looks okay from what I can see up near the head, etc.
The front end is up real high, anywhere else I should look while it is up?
Suppose that I should start it and listen, bit nervous going under there as it is.
1996 850 NA Loud When Cold Topic is solved
PeteB
- Year and Model: 1996 Volvo 850 Wagon
- Has thanked: 57 times
- Been thanked: 11 times
Listened underneath with it running and it seemed to be coming from behind the cat
or perhaps further back. Have to jack up the back of the car and listen/look there.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
The flange that's connecting the cat to the rest of the exhaust is somewhat of a trouble spot. That's where I had a leak too. Fortunately, it's a fairly easy fix. But since it's kind of in the center of the car you need get it up on all fours.
Good luck, Dirk
Good luck, Dirk
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- 850 LPT
If I remember right there is a conical spacer between the pipe flanges that was deteriorated. A new one plus new hardware installed with some exhaust sealer putty fixed the problem.
13' Honda Odyssey
13' Honda Odyssey
PeteB
Put the rear up on car ramps and you are correct that both ends need to be lifted.
There is a small 3/8" hole in the muffler, otherwise it looks fine. Covering it makes
almost no change in the sound but there is a bit of pressure there so I'm going to
patch by epoxying on an aluminium flashing patch.
The rear joint is very rusty and has just a bit of black carbon showing, going to cut
the bolts with a dremel and take a closer look. The clamp with bolts is $6 at FCP
so I'm going to buy one when I pass by FCP today.
The whole system looks pretty solid but I bet that those pipes are rusted at that slip
on joint.
on joint.
PeteB
On closer inspection one of the nuts holding the joint behind the cat was completely
rusted away and the other did not have much left. The pipes are in decent shape,
put the new clamp on and it worked fine. That was easy.
PeteB
Looking further back the rear most tail pipe hanger bracket is almost ready
to fall off due to rust. Going to look for a replacement on ebay.
The rest of the exhaust system looks to be in very good shape.
Found this on ebay, but also need the bracket bolted to the chassis:
- 754 Views
Last post by doublebug
- 12 Replies
- 5550 Views
- 3115 Views
Last post by nucci480
- 433 Views
Last post by Rbaratt
- 2059 Views
Last post by matomorizo
