What kills a battery in 6 hours?
- Been thanked: 4067 times
Definitely finde source of that drain - you don't want to cycle a battery like that too many times.
- Has thanked: 311 times
- Been thanked: 817 times
Just for the record - yes. Totally normal.rocketman4321 wrote: 16 Jul 2017, 19:13 ...
One oddity: when I first connect the battery, the clock/trip display turns on every segment, and the "icy road" warning light is lit. This goes away after maybe 45 seconds, and the clock is displayed as expected. Is this normal?
THat's all I've got on this one, alas. My first reaction is "maybe the voltmeter was screwy when the 8 V measurement was taken." For example, my smart charger thingy (it's a cheap-o from HF) will refuse to charge a battery with V that low.
Just for the record: yes, totally normal.rocketman4321 wrote: 16 Jul 2017, 19:13... One oddity: when I first connect the battery, the clock/trip display turns on every segment, and the "icy road" warning light is lit. This goes away after maybe 45 seconds, and the clock is displayed as expected. Is this normal? ...
That's all I've got on this one, alas. My first thought was "maybe the voltmeter was screwy on the 8 V reading." For example, my cheap-o smart charger thingy (from HF) will refuse to charge a battery that low.
rocketman4321
- Year and Model: 850 Turbo 1996
Voltage read by the charger was pretty consistent with my DVM. Charger is a Solar ProLogix 2310. I've only had it a few months, but happy so far. It did read 3% state of charge when it started that low!
rocketman4321
A bit of an update. After a half-hour drive in local traffic today, the battery was at 12.6 V. However, when I restarted the car, I was seeing 13.5-13.6V at the battery terminals. I've tested the harness drop and it's in spec. Could this mean the voltage regulator is short a diode? The voltage was reasonably stable with engine speed, and dropped slightly under heavy load, as expected.
I also yanked and pulled on the battery terminals to see if anything was obviously fractured, and they seem solid--voltage stable.
