Loss of power after starting
doshenjen
Year and Model: 98 V70
Post by doshenjen »
My 98 V70 loses power usually after the startup in the am: car starts, then when I reverse and point in down the drive (in forward) all power is lost; Putting it back in park (or neutral) car starts and runs fine the rest of the day. This only happens in the morning and not any other time of day. Any thoughts?
Has thanked: 1613 times
Been thanked: 4075 times
That sounds a bit like lawn mower syndrome - a bit of excess fuel is causing low compression.
Does it smell like varnish in the exhaust when this happens?
doshenjen
Post by doshenjen »
No smell is evident. also, doesn't happen everytime.
Is it stalling when you go into park or just running with no power?
Stalling is usually a vacuum leak, a bad hose somewhere
doshenjen
Post by doshenjen »
usually looses power (radio goes off, ignition turns off) when I put it into drive
