Does anyone know on what connector under the dash is the +12 volt supply for the reverse lights located on a 2000 V70XC?
Thanks!
Reverse light wire location Topic is solved
The rear lights on the 1999- models are controlled by a rear electronics module, not a conventional hot wire, switch, lamp System. You can find these diagrams on the web.
We have a legal agreement with Volvo to not host them here, but posting excerpts is fine
There is a hot wire, no REM on my 2000. It's a light blue wire in a red connector under the dash.abscate wrote: 26 Jul 2017, 20:47 The rear lights on the 1999- models are controlled by a rear electronics module, not a conventional hot wire, switch, lamp System. You can find these diagrams on the web.
2000 V70XC 160,000mi.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
There - Fixed that for ya!abscate wrote: 26 Jul 2017, 20:47 The rear lights on the 2001- P2 models
a conventional hot wire, switch, lamp system.
Barf,...pulled up the 2005 diagram by mistake
Sorry about that folks, nothing to see hear, move along, shows over....
OP...the wiring bundle through the left trunk hinge is a known weak spot for wiring failures on old P80s
I was looking for it so I could tap it for my auto dimming rear view mirrorabscate wrote: 27 Jul 2017, 04:15 Barf,...pulled up the 2005 diagram by mistake
- 2012 Views
Last post by Krons
- 12 Replies
- 6591 Views
Last post by mrbrian200
- 9847 Views
Last post by Krons
- 414 Views
Last post by Krons
- 912 Views
Last post by belskee
