People,
Car is a V70 1998 with312K miles. Had been running fine (a summer Maine island car) since purchased in 2013. Died at home. We pulled and cleaned the PNP switch and got it started. Ran fine for a week and died again. We checked the alignment using the rear brake lights but no joy. So we ordered a new switch and installed and aligned it. Still no joy.
Any suggestions before we junk the car? It would be a shame as everything else works and there is no rust.
Thanks
Dave
V70 1998 - New PNP Switch does not fix the problem
davidvinograd
- Year and Model: V70 1998
Reason: No "Help" in titles please. Edited title.
- Been thanked: 4068 times
What the problem, David? Are you having transmission trouble or a no-start?
davidvinograd
Car is no start. Diag tester shows P0705. Is there any way to by pass this safety check. Island cars do not have to pass any inspection.
Dave
Dave
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Happen to test the old one and verify definitively that it is bad? Could be something within the wiring harness - a bad ground, a backed out pin, a small spot of corrosion, etc.
davidvinograd
No, did not test the old switch. The new one came with a short cable - when we pulled the old one we detached it at the unit. So I will assume the supplied cable is good? How far back up the cable run do we go? Will pursue tomorrow in the light of day.
- 1063 Views
Last post by tardcart
- 40 Replies
- 16959 Views
Last post by Oly850
- 11 Replies
- 11415 Views
- 1627 Views
Last post by beigg
- 21 Replies
- 4140 Views
Last post by mdgilmore1956
