Door handle washer - 1992 Volvo 244 sedan GL
Rob1
Year and Model: 1992 - 240 GL
Post by Rob1 »
The door handle fits in to a washer (item 3 on attached drawing) and then turns 90 degrees and then you turn it and attach the screws. The washer fits in between two pieces of metal in the door. I believe the concave part of the washer faces toward the interior.
Problem: The washer ( item 3 )slips down between the two pieces of metal. Is there a clip that holds it in place or a certain way it fits in there?
Thanks,
Rob
Volvo door handle.pdf
(163.2 KiB) Downloaded 242 times
