850 Turbo Zero Boost
- Nevada1906
- Year and Model: 1995 850 Turbo
- Been thanked: 30 times
I took the bypass valve apart and the diaphragm was fine, so i reassembled it.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
- Has thanked: 1611 times
- Been thanked: 4075 times
I'm not positive this will work but perhaps you can confirm boost pressure by looking at the output on the boospt return hose on the Boost. Solenoid.
Boost pressure comes from the turbo casing, goes up to the boost solenoid, and then is switched to either the wastegate (boost requested) or the air intake ( no boost). You should be able to confirm pressure at the air intake line to test for blockages
- Nevada1906
Everyone, thanks for your help.
Because of availability and frankly extortionate pricing of the stock piece, I've got a MAC solenoid on the way.
Its exanguinating, not extortionate. We are a stickler for accuracy here on MVS...
- Has thanked: 2211 times
The TCU at this age is past it's best. The valve's fail in them and then the turbo does not get the signal to boost. Are there any parts yards around you where you can even pull a used one to try? 850's have a different shaped one to the V/S70's but I believe they can be interchanged even if it is not pretty at least to check it out. I have several but it would take a while to get one to you.
Good luck with the aftermarket part.
tryingbe
- Year and Model: None
- Been thanked: 26 times
I'd pull the vacuum hose at the actuator and see if you can make boost before buying a TCV replacement.
Pull the downpipe and look inside the turbine housing to see if the punk is still in place.
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- Nevada1906
scot850,
I considered going to a junkyard, but when 850s show up in the yards around here, they're pushing a quarter-million miles. Best to just replace the part with something new. Thanks for the offer, but I need to get this sorted out by Monday.
- Nevada1906
tryingbe,
I hear what you're saying, but the factory part did its job for King and country - it lasted nearly a quarter-million miles. Best to replace it and eliminate that particular question mark.
At least if this isn't causing the problem, it's one more thing I can check off the list the next time something goes wrong.
Don't disagree on the chance of a good TCV being in the junkyard, but they may be good enough to know if you are going in the right direction. I think I pay about $5 for them. I would agree a new part is preferable as it is probably overdue being replaced, but throwing new parts when not sure a part is faulty gets expensive quickly (as me how I know....!), so it was a suggestion to keep diagnostic costs down.
- 1387 Views
- 10 Replies
- 2483 Views
Last post by dux02v70
- 10375 Views
Last post by FREEBUSINESSES
- 1069 Views
Last post by vtl
- 1750 Views
Last post by yagger
