2005 S60 ABS Pump Motor Replacement Topic is solved
This topic is in the MVS Volvo Repair Database » ABS Pump Replacement DIY for 2001-2009 S60
youropeen
Year and Model: 2007 V70 R/2005 XC70
Post by youropeen »
Does anyone know if a motor out of a non DSTC car work in my car that has DSTC. I've been getting the intermittent 0070 code which is happening more frequently and staying on longer. I have several cars to choose from at the pick and pull but I'm not sure if any have DSTC or not and if it even matters.
Has thanked: 1609 times
Been thanked: 4064 times
I've got this one
ABS Pump Motor 8619543 $105
mrscullini
Year and Model: 05 XC70, 08 XC70
Post by mrscullini »
ReWagner wrote: 28 Sep 2016, 18:53 For some time I have had an ABS message - with trouble codes BTM0070 (pump motor supply voltage, faulty signal) and BCH0072 (pump motor, mechanical error). The online information that I could find suggested that the likely problem was a faulty Brake Control Module.
At first the ABS message was intermittent, then continuous. I got a used BCM and replaced the old one. That solved the problem for a while, but it became intermittent again, then continuous.
I sent the original BCM to XeModEx and had it rebuilt, to repair the power leads and to put a more robust pump driver in it. That solved the problem for a while again, but the ABS message soon returned intermittently. I called XeModEx and they told me that often the pump motor is faulty, rather than the BCM.
So I bought a used ABS pump motor and replaced the old one. That has solved the problem.
I am posting because I could find no reliable information on how to replace the ABS pump motor itself, without taking the entire ABS pump assembly out of the vehicle. That would have required the brake lines to be removed from the ABS pump assembly, and when the ABS pump assembly is reinstalled the brake lines would need to be bled.
Instead, I found that it is possible to remove and replace the ABS pump motor without taking the ABS pump or the BCM out of the vehicle. That avoids the need to remove the brake lines from the ABS pump, so it is not necessary to bleed the brake lines after the repair.
I am including what I learned about how to make the ABS pump motor replacement in the attached document. There are some photos in the attachment that may help understand how to do it. Perhaps this information will be useful to someone with the same problem.
great info, thanks rewagner.
battling the same issue in my '05 xc70. i can tap on the pump motor and get the abs light and error to disappear for a while. figure it is the motor.
the motor on there now has a label with the following, P30643979 and 10.0204-0414.4. does anybody know which other motors are compatible?
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
Post by Metallo »
ReWagner wrote: 28 Sep 2016, 18:53 I sent the original BCM to XeModEx and had it rebuilt, to repair the power leads and to put a more robust pump driver in it. That solved the problem for a while again, but the ABS message soon returned intermittently. I called XeModEx and they told me that often the pump motor is faulty, rather than the BCM.
Hi!
I wonder if you can help me with my question.
I had a very similar problem with my XC70 2005 ABS/Anti-Skid service required.
I had BCM-0070 and BCM-0072 errors, so I sent the BCM module to XeMODex and once I got it back and re-installed it the warning message disappeared.
After three/four weeks the ABS light on the dashboard as well as the "ABS/Anti-Skid service required" message on the dashboard.
I ran VIDA and the only error I get now is BCM-0070, therefore I presume the motor is the culprit.
I will follow your instructions to disassemble it, however I have two questions to you:
If I find a new ABS Pump and put it on, will I have to reset it in order to get it to work?
Or you can simply buy a used pump, put it on and it will work?
If I have to reset it, is it something you can do in VIDA?
Any advice you can provide if very much appreciated.
Thank you!
Alex
Polar 940 Turbo SW - 1997
Metallo
Post by Metallo »
Hi there,
I am re-assembling the ABS motor after having cleaned it, would anybody be able to confirm me if the washer under the bearing is set in the right direction?
I took pictures before disassembling the motor, but due to a shade, that detail is no visible.
Thank you
Alex
Metallo
Post by Metallo »
I would expect to be the other way as on picture one, the three little dots, I would not expect those to be in contact with the bearing.
Also, do I need to put some grease between the washer and the bearing?
Finally, does the bearing need to be pushed to the bottom of the shaft and be flushed with it or slightly higher to allow the bearing to work freely?
Alex
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Metallo wrote: 06 May 2018, 07:47
Hi!
Thank you!
Alex
Don't know for the codes, but I'd check first the axle bolts are tight (don't overtighten) and the axle abs rings (reluctors) don't have a small crack
537playing
Year and Model: 2005 S60
Been thanked: 5 times
Post by 537playing »
I followed the method described by ReWagner. Excellent solution for the BCM 0070 and 0072 codes.
