1999 C70 quit running while driving down the road ( recloned ECU) Topic is solved
Has thanked: 1614 times
Been thanked: 4078 times
Definitely different on ME7
The car will always crank, with a key without a married chip it will start and tun for 1-2 seconds, then die. Subsequently, it will crank and not fire.
I don't know if it inhibits spark, fuel, both, or Oxford commas.
I have got both a cam sensor and ring antenna in my stash , can check part numbers tonight
volvooh
Year and Model: '98 S70, '05&'08 V70
Been thanked: 4 times
Post by volvooh »
Just an update here.
I was able to get my hands on a denso cam sensor and antenna ring. The denso sensor was brand new. I installed it but no change. I got the key ring antenna from my son's '99 S70 (same MY as the C70) and still crank no start.
So it appears I have eliminated the Cam sensor and antenna. I was also able to attache a fuel pressure guage I am getting 52-54 psi while cranking.
Interestingly after I played with the antenna this afternoon (and it did not start), I came out an hour later and with a little cranking, started. Ran @ idle for about 10 min before it died again.
I appear to be getting a weak, intermidtant spark. If you crank it enough, it will try but will not catch and if it does only for a short while. Same with Starting fluid.
Should I order the Dice system to do a deeper check?
Okay , let's look at the 12 CDC on the coil packs. The wiring diagram is in a thread called coil wiring assignments , or close to that
It's terminal 4 on each coil. They should all be at battery voltage ( measure that) with key in Position II , engine off
They trace back up to relays that supply critical voltages. I found a lot of thermal damage in my Albany Volvofest thread and documented cleaning those there.
( search Albany Volvo Fest, it's down the thread a bit)
PS..I got your note on wiper switches, Evan paid me a box forward so I will do the same when I get to the stash today,
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Sounds like it is loosing battery power, how are the cables?
volvooh
Post by volvooh »
Abscate- I measured 12.2 volts at each coil prior to starting. It started and ran for 5 to 6 minutes. Rechecked and it was 11.8 volts after it died.
Rspi- Interestingly the battery was at 12.7 V this morning. I put it on the charger and raised it about 13.6 prior to starting. After it ran voltage steadily decreased to 13.0 before it died.
I'd like to run a voltage test directly from the alternator.
volvooh
Post by volvooh »
More numbers. I was able to start it up again as usual a couple hours later. I got a reading directly off the back of the alternator. When the car stopped running I was getting 13.8 to 13.9 off of the alternator. Checked battery voltage after it quit running and I was at 12.2 v. Voltage off coils was 12.01 V with key in II postion.
Abscate- are the relays you are referring to the 4 silver ones in the fuse box?
Those are big voltage drops. It should be right at battery voltage and stay there. electronic stuff is not like points and condenser ignition systems , it likes good steady voltages.
There is a main power relay that feeds both the coils and injectors under the hood, I'll post a manual pic
volvooh
Post by volvooh »
I had to take a break from this yesterday. Its driving me nuts.
So here is where I am at. I have swapped out a cam sensor, replaced and jumped the fuel relay. I have scanned with my OBDII and no codes. I have 55lbs of pressure at the rail. My voltage readings I posted last weekend were I believe in error. I check them myself three times and each I was getting a consistant high 13.5 to low 13.6 with the head lights on @ the battery. I am getting a consistant 13.7 to 13.8 at the alternator.
The car consistantly starts now when the engine is cool. BTW I want to view fuel pressure up to the point of failure to rule out a fuel pump heating up and cutting out. Would it you know it it started and idled for a good 10 minutes (kind of rough though) before a hose on my fuel guage ruptured. Until that point I was getting a consistant 53 to 55 lbs of pressure. Of course when I started it back up after the guage was removed it started for a just a few seconds and stallled.
I am thinking of swapping out the crank sensor and then the ECT maybe? I know a crank sensor should not kill the engine, but it appears the engine stalls as it is heating up and restarts after it cools down.
volvooh
Post by volvooh »
I was also thinking about the MAF. I noticed when I was running it yesterday afternoon and disconnected the MAF it immediately killed the engine. Hooked it back up and it ran again. I also noticed by disconnected the MAF and spraying starting fluid in I got the car to fire. Reconnected and spray SF and nothing.
Could a failed MAF be my issue?
