I have been chasing a fan that won't run problem on a new to me car someone else put a motor in. (Thanks to Ozark Lee for a previous post on the fan relay and what each wire is for.) the big red lead that comes out to a white wire at the starter was not connected and I thought it was solved at that point but now it isn't working again and a volt/ohm meter tells me all is good but the black wire that should be zero ohms to ground is open(failure was intermittent during some of my tests) . Given that someone swapped the engine I figure I'll put it up on the lift and poke around. Maybe there is some more wiring that isn't connected. It is also throwing a knock sensor 1 code instantly after clearing i so maybe that isn't plugged up either.
Anyone know where the big black ground plug to the radiator fan terminates?
96 850T engine wiring
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- greg850r
The big black ground wire exits the harness right next to where the dipstick tube enters the front of the block and terminates there where it is bolted to the engine block with a 12mm bolt. It was loose, hence intermittent ground that made diagnosis difficult. Also found the knock sensor plug for the hard to get to one (pass side) plugged in to the EGR under the intake. Now to re-install the fan I shouldn't have pulled......
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- Has thanked: 2200 times
Hopefully that was your car's issue. The PO is not and will not be the only one to miss connecting a wire or 2 on an engine swap!
Let us know how it works out.
