Timing marks '04 V70 - viewing
SuperHerman
Been thanked: 178 times
Re: Timing marks '04 V70 - viewing
Post by SuperHerman »
My fault - I thought you had attached a video. I confused it with another similar post.
Regardless, any updates?
Faust
Year and Model: XC70 2005
Has thanked: 14 times
Been thanked: 4 times
Post by Faust »
"Regardless, any updates?
I have the belt cover off, but unable to detect any marks on the crank pulley.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
jonesg
Year and Model: 2004 V70
Has thanked: 2 times
Been thanked: 47 times
Post by jonesg »
THe marks are not easy to see, just a tick on the top of the gear tooth.
SuperHerman
Again, just pull of the wheel, the one 10mm plastic nut, fold back the plastic access panel and remove the four bolts holding the harmonic balancer.
You will see the mark right away. After this if the gear teeth have markings (which mine did not) they will be now be evident.
I assure you time will be saved.
SuperHerman
Look at the pictures in the PDF that is in the last post. They show the "marked" teeth for his car - possibly yours is the same.
viewtopic.php?f=9&t=77183
Faust
Post by Faust »
"Again, just pull of the wheel, the one 10mm plastic nut, fold back the plastic access panel and remove the four bolts holding the harmonic balancer."
I'd done all that save pulling the harmonic balancer, I'l;l try that,.
2004 V70
jonesg
Post by jonesg »
Timing marks are visible in this video, you are probably looking in the wrong place, they are not at the 12 o'clock position.
More like 10 oclock .
