SRS Light On s70 t5
speedyt5
Year and Model: s70 t5, 1999
Post by speedyt5 »
Tried searching, but wasn't able to find anything. The SRS light is on now, it says it is the passenger side airbag in the seat. This is weird because 3 years ago I put new seats in and before I put the new seat in the old seat also had this exact same thing. Anyways, is the old story true that the airbags will not deploy in a crash or is that just an old wives tale? I know there is only one way to find out, but I don't want to test it.
Has thanked: 1609 times
Been thanked: 4065 times
You have to read the. Actual fault code to determine this.
On a 99, the seat bags are fired by the SRS controller, not impact, so whether you have working air bags depends on the fault.
speedyt5
Post by speedyt5 »
It says its the right side airbag, but by the SRS light being on at all does that mean that none of the airbags would fire in an accident? I have heard that it just shuts the all down.
Has thanked: 2199 times
Been thanked: 1852 times
First obvious thing is to check the wiring to the harness has not broken. Constant movement of seats can cause some wire to fracture with age.
My understanding is if the SRS light is on, then the system is disabled completely. Check in you hand-book or call the dealer if you don't get a better answer.
I have not seen a reputable source discuss the SRS software.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
YOU HAVE NO WORKING AIRBAGS...NONE
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
One likely culprit is the connector with the orange wire has corrosion. This is close to the seat base.
Simply remove this connector and clean it and then get the the SRS code cleared. On this model year you need a code clearer that can talk to the SRS module. Apart from a dealer you can try the Autel MD 519 or a Vida/Dice setup (laptop required).
The SRS system is pretty robust. After clearing the SRS code in my 2000 V70 due to corrosion in the aforementioned connector I drove it for another 5 years with no SRS mishaps. In fact in all our Volvos (about 10 of them by now) we had no SRS issues apart from not disconnecting the battery before working on SRS related components as this will give you an SRS warning.
abscate wrote: 11 Aug 2017, 20:56 I have not seen a reputable source discuss the SRS software.
I have seen one reputable source discuss SRS software.
Thanks, Jim
baxtex
Year and Model: Volvo S70 99
Post by baxtex »
Borrowing this thread. On my S70 -99 the SRS light tends to light on for a few seconds when I start the car and then it turns off again. Is this some indicator that something is wrong? I have checked error codes but haven't found anything.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I had an SRS light on after son left window open overnight in rainstorm. Moisture had gotten to the seat airbag wiring. Based on a suggestion (I think it was from Neil or Steve, but I may be mistaken) I dried the wiring out and my local independent reset the SRS light for me. No problems since.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
