I will clear the codes now, thanks for that useful info! As soon as I have access to star wrenches (which should be soon) I will be replacing the seal. I did the rubber glove test and it inflated, removed dip-stick from well and saw white smoke consistantly coming up. Do I need to be careful with anything more than normal when replacing the seal? Like is there a filament or something that should not get wet or touched.erikv11 wrote: 14 Aug 2017, 09:28 Battery disconnect definitely clears the codes. Remove both wires and touch them together if you want to be certain.
All of the misfire codes likely come from the rear cam seal, which is blown out due to the clogged PCV and piping moisture and oil into the distributor cap. Pull the dipstick to relieve crankcase pressure, replace the cam seals (use Corteco or Volvo seals, do not use Elring or other cheap seals unless you are content to replace them again in 6 months) and clean out the cap when you are finished.
If you bought Bosch wires those are known to be troublesome and could be part of the misfire problem, there are very few wires that "work" with these cars. The best deal is Bougicord wires which are usually cheapest ordered online.
What plugs did you use? Bosch coppers should work just great, but what are they gapped?
I feel like the wires are not the problem, and would like to exhaust all other possible options before replacing the wires AGAIN.
I just used what the O'Reilly employee told me would work with the car. I have no idea what they are gapped to, and don't even know how to find out.
