1995 volvo 850 radio issue
galerie
Year and Model: 1995 850 GLT
Post by galerie »
the other day, I turned on my car, the radio came on for about 5 minutes and went out. I checked the fuses and the radio fuse is good, could there be other issues I am not aware of, or did my radio finally give in
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Is the radio doing anything at all? It could be related to wiring. Make sure the connectors are in all the way, obviously.
Your best bet after checking those things would be grab one from the junkyard to test it (they're usually like 25-30 bucks, make sure it has a code with it) or take this as an opportunity to upgrade.
galerie
Post by galerie »
nothing at all, the display is blank, I will take it out and make sure all connectors are tight...and see if I can find one at the junkyard...usually these radios are the first to go...
Has thanked: 2199 times
Been thanked: 1852 times
Not sure why the radios go so fast down there. The only ones that go here are the SC-901's and most folk then forget to take the wiring link to the amp and the amp.
The rest get torn open by the gorilla's too cheap to buy new bulbs.
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
I have a couple I know work, I'm in VA PM me if you are interested. I assume you want a unit with a CD?
bmdubya1198
scot850 wrote: 16 Aug 2017, 17:55
That was one time I did that...
...actually I had to get a new faceplate ribbon connector because I broke it replacing light bulbs. Which didn't even work :evil:
galerie
Post by galerie »
rguzz wrote: 16 Aug 2017, 19:59 I have a couple I know work, I'm in VA PM me if you are interested. I assume you want a unit with a CD?
I have a 6 disc CD player, so I am just looking for the Sc-811 with just the cassette player?
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
The 1997 radio with a single CD slot has the same plug for a remote CD player. The 1998+ cars have gray plastic rather than black.
Klaus
