Step 36: Remove spindle
Step 37: Remove axle
Step 38: Remove sway bar link
Repeat Steps XX-39 for other side of the vehicle
Step 39: Remove front engine mount bolts
Step 40: Remove front exhaust hanger bolts
2001 V70 T5 Auto transaxle problems
01_Nautic_V70
- Year and Model: 2008 XC90 V8
- Been thanked: 8 times
01_Nautic_V70
Step 41: Remove intermediate exhaust plate
Step 42: Remove steering rack bolt (1) and nuts (4)
Step 43: Remove lower bolt from radiator side engine mount
Step 44: Remove top nut from firewall side engine mount
01_Nautic_V70
01_Nautic_V70
Step 45: Install a bridge or lifting device to tilt the engine out of the way
Step 46: Remove subframe from under car
Step 47: Remove transmission ground wire
Step 48: Remove rear engine mount from transmission
Step 49: Raise front of engine 1-2", lower rear of engine ~6"
Step 50: Lower rear of engine until transmission will clear fender liner as removed
01_Nautic_V70
Step 51: Remove transmission
Step 52: Remove torque converter
The old transmission is out!
01_Nautic_V70
The new transmission has had the axle seals replaced, filter replaced, and generally cleaned.
The "new" tranmission is a 01K... serial number and thus has a suspect B4 Servo cover. Luckily, I had installed the updated cover on the old transmission, so it's a matter of swapping this.
01_Nautic_V70
Here are some shots of the differences in the B4 servo covers
Old B4 servo cover underside Old B4 servo cover top Old B4 servo cover side view New B4 servo cover underside New B4 servo cover top New B4 servo cover side view
01_Nautic_V70
From this point, the new transmission is prepped and ready to go back in. I have reversed all of the previously posted steps.
Using low pressure air, flush all fluid possible from the transmission cooler.
Using gravity and low pressure air, flush the transmission cooler hoses.
Remove and replace the inline transmission filter (I had put one into the trans cooler supply line)
New fluids all around (coolant, ATF and oil)
New filters (air and oil)
Installed new silicone hoses to turbo control valve as these looked quite aged.
Rotated tires.
All buttoned up and the car is running great, started with no codes at all. Reset the trans fluid counter via VIDA. Shifts beautifully with no flares. Will take it in for a front end alignment (since this was disassembled to the point of not being on the car anymore) this coming weekend and do a drive cycle/adaptation reset and cross my fingers that this little Swedish wagon runs great for the next 150,000 miles.
Rotated tires.
- Year and Model: Lots
- Been thanked: 128 times
Well documented. This is definitely the go-to resource for anyone contemplating the same repair.
01_Nautic_V70
Thank you. I'm no professional mechanic, but this is certainly possible in a garage setting with hand tools, patience and a beer fridge.precopster wrote: 23 Aug 2017, 04:47 Well documented. This is definitely the go-to resource for anyone contemplating the same repair.
- 1381 Views
Last post by Ozark Lee
- 1662 Views
Last post by MadeInJapan
- 893 Views
Last post by theWIFES_S70
- 15 Replies
- 2088 Views
- 745 Views
Last post by Nadiamarie22
