Where is this part located?
Bourgeois0424
Year and Model: 1997 850 GLT
Post by Bourgeois0424 »
Obvious Novice here with a novice question. Where is this part located? Replaced some things last week and when I went to put it all back together I realized I had this part that rolled away from everything else and can not for the life of me find where it goes. Go easy on me lol thanks
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Been thanked: 4068 times
Somewhere in the evap canister vacuum hose snake pit..
misha
Post by misha »
No abscate...it is located at FCPeuro. :D
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 2203 times
Been thanked: 1852 times
Abscate is correct in that it is part of the emissions pipework horror show.
If this link works, then it is item #22 in the diagram which may help you figure out what it attaches to:
https://www.volvopartswebstore.com/prod ... 86744.html
Interestingly, according to my version of Vida that part number is not fitted to an 850, let alone a 97 850 GLT (low pressure turbo).
When I look at the Vida layouts for the 97 850 GLT it does not list or show this part for your car (assuming the car is the one in your profile).
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Volvo used so many different emission system setups, it probably was fitted at least one '97 850. I would assume a '97 GLT would be the same as my '98 GLT, but again, who knows.
My car has the rear charcoal canister near the gas tank. Assuming you have the front charcoal canister setup, look at the diagram Neil posted.
Bourgeois0424
The diagram was what I needed, got it reconnected. Tried searching for awhile for a diagram like that lol Yes this is the car listed in my profile. That is interesting though. Thanks a lot!
misha wrote: 23 Aug 2017, 14:56 No abscate...it is located at FCPeuro. :D
Nicely done!!!
:x
bmdubya1198
abscate wrote: 23 Aug 2017, 17:09
Nicely done!!!
:x
Look at Misha stealing your thunder :mrgreen:
Well done figuring it out. Glad we were able to help you out.
