Retracting brake pads
Penhallow
Year and Model: 2003 v70
Post by Penhallow »
Hi, I have to renew front and rear pads on a v70 (2003) On other cars that I have owned the manuals always state that if the vehicle has ABS then the the bleed valve should be opened whilst pushing back the piston(s) so not to damage the ABS unit, If the pads are being renewed there could be an overflow of fluid at the master cylinder,so maybe that advice is the way to go ?
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
It seems to me if the bleeder valve is open the excess fluid will exit the bleeder valve rather than backup through the system to the master cylinder. After all isn't that the point to opening the bleeder before retracting the caliper piston? June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
Has thanked: 1505 times
Been thanked: 3818 times
Open the bleeder, since you are going to replace your > 24 month old brake fluid anyway, per the Volvo recommendation, right?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Some had luck pushing the piston back without opening the bleeder. However, I've read of few people who had problems with the ABS afterwards, perhaps some valve was forced/damaged. So play it safe, open the bleeder. Rear bleeders can be very stuck, don't force or they will break.
jbeebo
Year and Model: S60, 2005
Been thanked: 3 times
Post by jbeebo »
Open the bleeder, don't force that nasty fluid in reverse back thru the ABS valve body. An analogy is drinking the water that comes off a reverse flush of a water filter - blech. or when your drain line gets backed up and effluent reverses flow out of the shower drain all over the floor - double blech.
After you've replaced the brakes you may need to add fresh brake fluid to replace what was lost.
2005 S60 2.4L (B5244S6), 175k miles
Penhallow
Post by Penhallow »
Thanks for the replies, I will open the bleed valves as I have done on other vehicles,may do a whole flush at a later date, also went for the annual (mot,itv) test today, passed with flying colours,the emissions were way down !! (Blocked off EGR ) !
