1996 850 Turbo no spark mystery?
eyewillruleu2
- Year and Model: 1996 850 turbo
as is common, pulled up and got fuel shut car off and wouldn't restart. got towed home and went through the basics turned key on fuel pump Dickson for a second and check pressure ect. it's fine. checked for spark? nothing. long story short Newham sensor New ignition switch and coil and crank sensor checks out good. wires, cap and rotor are good. don't know if it's related but an hour before that a female friend turned the radio volume up all the way instead of down and when she did it cut off as in blew the fuse dead. pur a New fuse in and itdoesnt work. also before I changed the ignition switch I removed both battery cable from the battery and put a charger on it. and when I hooked it back up to tried to start the car the little lights on the AC button and the one next to it are flashing?? I'm at witty end! help please!
- Been thanked: 4068 times
- Has thanked: 311 times
- Been thanked: 817 times
Does this car have an alarm system, did you try locking and unlocking with the key in the driver's door?
eyewillruleu2
Yes but I'm wondering if the hood needs to be shut as well because I think there's some kind of sensors on each side of the hood?,
- 2220 Views
Last post by Ozark Lee
- 3426 Views
Last post by dcarlson12
- 1983 Views
Last post by banjoman
- 13 Replies
- 2353 Views
Last post by E Showell
- 3062 Views
Last post by Roger_850T
