'99 S70 Base 138K miles - Dash Bulb Warning Light Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
One of my license plate lights was out causing the dash bulb warning indicator lamp to light. I changed both license plate light bulbs, but that did not extinguish the bulb warning light on the dash. In the past when I've had a burned out headlight and replaced it, the bulb indicator lamp reset itself. Is there some reason it isn't doing so now after the license plate bulb replacement? I have a scanner, but as far as I know, it won't reset the bulb warning light.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 1839 times
- Been thanked: 1709 times
You may have to do what I did and pull each bulb and check it out for damage/rust/abnormalities which may make the system think there is a problem.
Neil
Neil
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
The license plate lamps aren't part of the warning system.E Showell wrote: ↑13 Jul 2017, 19:35 One of my license plate lights was out causing the dash bulb warning indicator lamp to light. I changed both license plate light bulbs, but that did not extinguish the bulb warning light on the dash. In the past when I've had a burned out headlight and replaced it, the bulb indicator lamp reset itself. Is there some reason it isn't doing so now after the license plate bulb replacement? I have a scanner, but as far as I know, it won't reset the bulb warning light.
Bulb failure warning light
The light will come on if any of the following bulbs are defective:
one of the low beam headlights
one of the tail lights
one of the brake lights when the brake pedal is depressed.
Check the fuse and bulb. See sections "Replacing bulbs" and "fuses".
Should the warning light come on after a defective outside bulb has been replaced,
the corresponding bulb on the other side of the car should also be replaced.
You have another problem - Probably dirty contacts.
Solve it and the dash light will go out.
- E Showell
It was a tail light out.
'95 855 auto (sold)
'95 855 auto (sold)
Glad you got the little devil figured out!
- Has thanked: 1501 times
- Been thanked: 3812 times
Buy a two pack and replace both tail lights. Run those sentences concurrently,
- E Showell
That is my usual practice.
'95 855 auto (sold)
'95 855 auto (sold)
- 2471 Views
Last post by firstv70volvo
- 476 Views
Last post by foggydogg
