My 96 850 Turbo Wagon idles fine but dies with any load
Luke.T5R
Year and Model: 95 T5R, 96 850 Turbo
Has thanked: 2 times
Post by Luke.T5R »
I purchased this Turbo Wagon last year intending to drive it everyday, it has proven to be economical and reliable and it has really grown on our entire family. Recently it started to die under heavy load, (moving with the wheel all the way turned and with the AC on). I checked the codes and saw a knock sensor code (it does that one intermittently) and a MAF code. I had a spare MAF and IAC valve (my family has a lot of volvos) so i put both of those brand new parts on, and that took care of the MAF code but its actually worse. It will idle now but dies as soon as it goes into gear. Im sitting on a pile of parts and 1 parts car so i can troubleshoot easily. What do you guys think?
Black 95 T5R Wagon Manual Swap
Silver 96 850 Turbo Wagon Rebuilt(Almost) Daily(Almost)
Ugly Magenta 86 Honda Nighthawk 650
White 2006 Toyota Tacoma TRD
Black 2012 S60 T5 (Fiance's car)
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
She looks nice. Happen to check for large vac. /pressure leaks - such as the turbo pressure side? Could be a small leak that gets progressively worse as additional boost is provided, throwing the F/A mixture way out of spec.
Does it still do this if the A/C is off? Do any lights display on the dash with this issue shortly before or after it quits?
Luke.T5R
Post by Luke.T5R »
I have gone over the entirety of the charge piping, both hot and cold sides, no obvious leaks there that i can see. Idk if it will die with more boost, i cant even get it to run in gear to drive it and find out. Itll do it with the ac on or off, and no dash lights come on. It shudders and dies like if you stopped in a manual car with out pushing in the clutch
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
I would second the vacuum leak. I just found one on mine - one of the hoses was slipping off in a hidden spot. I'd also check all the little vacuum elbows - they can fail and are kind of hidden.
You didn't say - is it just dying at high load and at idle? How does it do driving down the road? Or will it not even get on the road? If it's just at idle, it may be that the idle air valve is stuck or failed. You can check the impedance of the coil, and you can check that the gate inside moves freely. Then you can flush it with some solvent and clean out any gunk that is in there.
Other than that, I am assuming that everything else is generally up to snuff (ignition etc.)
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Fuel pressure?
I was having issues with my '96 GLT, where it would occasionally act like it wasn't getting fuel.
The last straw was when I would try and take off from a stop one day (a manual) and it would just stumble and die, or almost die. It would idle all day, however.
I checked fuel pressure and found some irregularities, and opted to dig into the pump. I took the old one out and found this---
Someone had been in there previously and improperly installed the pump as well as used the wrong fuel hose. (non-submersible). Car was fine after an R&R of the pump with new hose.
A similar thing happened on my '80 240, but it was just degraded original fuel hose,
tryingbe
Year and Model: None
Post by tryingbe »
Luke.T5R wrote: 30 Aug 2017, 16:35 I have gone over the entirety of the charge piping, both hot and cold sides, no obvious leaks there that i can see. Idk if it will die with more boost, i cant even get it to run in gear to drive it and find out. Itll do it with the ac on or off, and no dash lights come on. It shudders and dies like if you stopped in a manual car with out pushing in the clutch
Take them all out and take a good look.
85 GLH, 367 whp
00 Insight, 72 mpg
Luke.T5R
Post by Luke.T5R »
Thanks for your suggestions! Im gonna dig into the car today and see if i can find any split lines or anything. Ill report back if i find anything or not.
tryingbe
Post by tryingbe »
people have reported cracked intercooler as well.
85 GLH, 367 whp
00 Insight, 72 mpg
Luke.T5R
Post by Luke.T5R »
Just went through the intercooler piping and none of the rubber was obviously cracked or anything. All of it looks relatively new. I also looked over the intercooler (what i could see) and didnt see anywhere it could be leaking. I also took a short video of what it does so you guys can see it too.
Chuck W
Post by Chuck W »
Check your FP and see what it is/does.
