2002 V70 xc turbo, no codes but running poorly, clean ETB? Topic is solved
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
I usually pick them up at auction, try to fix them and sell them to make extra $$. I think I'm up to 14 now and the best most reliable has been the 240's. Iv'e got a 92 with over 250K and all I do is put gas and oil in it. But.... I've had a couple that were just lemons it seems, always little quirks that I could not totally get rid of but I've never lost money on one yet, knock on wood.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
I picked up the new crank shaft position sensor and when I went to remove the old one it was very loose. I removed it, took the wide copper washer off the old one and removed the rubber O ring on the new one, slid the washer on and then the O ring and installed it. I'm not sure but is the threaded post that tightens the sensor down purposely set to not allow it to tighten past a certain depth? The threads on the post and nut did not show any signs that it was stripped but again got to a certain depth and stopped. Hooked up Vida cleared the codes, the same 3 showed up after the install. I took it for a quick spin and did not get the "reduced engine performance" yet but the real test will be tomorrow when my wife drives it to work on the highway. Fingers crossed and up next will be the tranny flush.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
Well, my wife is still getting the error code, "reduced engine performance". I'll check codes again tonight. ugh.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
Still getting 5200 code for RPM sensor. Am I missing something? ordered the crankshaft position sensor bracket thinking that since my threaded post is stripped that perhaps this is interfering with my signal. I can't tighten or remove the crankshaft sensor bolt. Will install part, erase codes and post back. ugh.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
You are in uncharted waters, Captain. I don't recall a recent thread fighting this code on a P2 but will look back
aaron1611
So I received the new crankshaft position sensor bracket yesterday and replaced it. The old one was split into two pieces and the threaded post had broken off on the bottom side and thus when I tried loosening or tightening it the post would just turn. Installed both new parts and I'm still in the same position. I'm getting the same "reduced engine performance" error and when I read the codes the, after erasing them, the code 5200 RPM sensor-signal too low shows up as a yellow ECM, meaning the DTC is found not active. I'm now also seeing, once so far but did not come back, 641A-exhaust camshaft control-slow regulation, also a DTC yellow, found not active.
I did notice that as soon as I turned key into position 2, with all accessories off and connected to Vida that my battery voltage immediately read 11.8V. however, once started it resumes to it's normal voltage. Might this be part of my problem?
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
- Year and Model: Lots
- Been thanked: 128 times
I doubt you have a battery problem. If the charging system produces enough voltage with engine running and car continues to start well you don't have electrical charging issues.
What perplexes me about your issue is that you've chased down the demon that the codes point to (coil pack and crank sensor) and still continue to have the issue. Might be time to purchase a ECM removal tool and clean all the contacts on the computer and receiver connector. Short of this producing a result I would look at fitting a used ECM. This is possible with the help of a couple of gurus here on MVS namely Yagger or Doublebug that can use your Dice over the internet to clone the key transponder codes and ECM firmware to a used ECM.
First thing though is to clean that ECM with contact cleaner by CRC or a similar product.
aaron1611
I can do that. Do I really need that tool? I replaced the ECM on a 2000 S70 & 2001 V70 Turbo without it, same procedure?
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Yes the pink sliders, if you have already worked it out it's the same setup. Hopefully this works for you.
aaron1611
so, I re-read the codes and erased them again and it's not thrown that error message in two days........not holding my breath but it's encouraging. Replacing the siren module after work today.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
