Geartronic shifter with knob that has center pin. Plastic broke around pin. Trying to figure out how to remove shifter so that I can replace the knob/trigger.
Videos I have found for other model Volvo's of same year seem to indicate that you must just pull up really hard on the shifter to remove it. Is this correct? Also has a leather skirt around base of shifter.
This is an automatic with T5 engine, 2 wheel drive.
Thanks!
2004 S80 shifter knob broken how to remove shifter
quietlymknnoise67
- Year and Model: 2003 C70
Twist boot ring connecting boot to the knob to release it from boot then pull straight up on knob very hard. It will come off from stem.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
These is how it goes on my S60, just detach the boot first as mentioned and watch your fingers
ictshocker
- Year and Model: 2004 S80
Thanks!
So same process for s60 and s80.then? Do I need to have trigger pushed in when pulling up? Button is gone so hoping not.
Any recommendations on disconnecting boot? I've twisted clockwise and counter to no avail.
Thanks!
Thanks!
quietlymknnoise67
After twist, push down on boot material. Pull up on knob hard. The whole thing will come out. Pry out button with flat blade and when you install it back work the slide onto the button stem.
- 946 Views
Last post by amblerman
- 734 Views
Last post by lummert
- 1356 Views
- 14 Replies
- 3270 Views
Last post by bmdubya1198
- 245 Views
Last post by 516volvo
